The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Disable LED dimming via coding
      03-10-2011, 12:26 PM   #1
SilverII
40
Drives: '11 335IS
2011 BMW 335IS  [9.66]
Does anyone know if we can disable the DRL LED on LCI e92 from dimming when turning on the headlights? I'd think it would look hot at night with the LED at full power around the projectors.
      03-10-2011, 02:19 PM   #2
dryicerx
27
Drives: 335is
I was actually wondering the same thing, would be awesome if possible.
Doesn't appear to be an option on Neutrino45's spreadsheet, it just may have not been stumbled upon yet...
      03-11-2011, 06:01 AM   #3
tldoxmf87
tldoxmf87's Avatar
South Korea
40
Drives: e92 TiAg
we need to figure this out..
E92 TiAg
      03-13-2011, 08:39 AM   #4
Toad335
32
Drives: LCI 335i
I searched through NFRM and found all of the following references to SL (the angel eyes?). A lot of them are also related to corner delete mod, so SL might be the turn signals...A couple sound promising, but I'm going to need someone with more coding experience/german to translate. The first two seem the most promising to me, as they refer to SL with high (FL) and low (AL) beams, and there are a number of options to choose = brightness??
The other one that sounds cool, though unrelated, is SIGNALBILD_SL. Has options for one or both lights. Wondering if this is like the Audi's that it turns off the AE when you are using your turn signal on one or both sides...
PWM_SL_V_BEI_AKTIVEN_AL
wert_01 value 01
wert_02 value 02
* wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_06 value 06
PWM_SL_V_BEI_AKTIVEN_FL
wert_01 value 01
wert_02 value 02
* wert_03 value 03
wert_04 value 04
wert_05 value 05
wert_06 value 06
IGR_MIT_SL_AL
* nicht_aktiv not active
aktiv active
SL_PARKL_ABSCH_12H
* aktiv active
SL_ABSCH_OHNE_ECE
* aktiv active
OPTIONEN_SL_ABSCH_TFL_FLC
* aktiv active
PWM_SL_V
wert_01 value 01
wert_02 value 02
* wert_03 value 03
wert_04 value 04
wert_05 value 05
NSW_FKT_SL
aktiv active
HECKKL_SL_LOGIK
aktiv active
PARKLICHT_MIT_SL_V
aktiv active
PO_RL_FKT_MIT_SL_V
* aktiv active
SIGNALBILD_SL
sl_1
sl_2
sl_1_und_sl_2
SL_SCHALT_UMSCHALT_OPT
wert_00 value 00
wert_01 value 01
* wert_02 value 02
wert_03 value 03
      03-19-2011, 09:36 AM   #5
tldoxmf87
tldoxmf87's Avatar
South Korea
40
Drives: e92 TiAg
Found a solution (not a coding solution though) in the forum..!
http://www.n54tech.com/forums/showthread.php?t=11714
E92 TiAg
      03-19-2011, 11:08 AM   #6
Toad335
32
Drives: LCI 335i
I'm not into shorting wires on my harnesses. Would rather do it via coding. Must be possible, given the number of things that are...
      04-05-2011, 09:31 AM   #7
Toad335
32
Drives: LCI 335i
Anyone do any more playing around with this? I haven't had time.
      05-27-2011, 08:25 AM   #8
Toad335
32
Drives: LCI 335i
Wondering if anyone has found a solution yet.
      05-28-2011, 12:13 PM   #9
Elliott@DetailAddict
300
Drives: E90
The answer is in recoding using non-standard variables. (NETTODAT)
      05-28-2011, 02:18 PM   #10
matrix76
matrix76's Avatar
61
Drives: 2020 Z4 M40i Black/Red
I believe the reference to the AE's is RL (ringlight)
Information provide to me via another member,
Originally Posted by Knob View Post
You should look for something like PWM_AN_SL_V_AL_1 or
PWM_ANSTEUERUNG_RL_BL_1 (RL = ringlight), it´s probably wert_02 or something, change it to wert_01... I don´t know if that works..
Brian
Black Sapphire, Black w/Burrwood Trim & Shifter, 162's, Mtec H8 AE's, DS1 HID 6000K
      05-29-2011, 09:03 AM   #11
Toad335
32
Drives: LCI 335i
Do you have the detailed answer, or just know that it can be done using this method but don't actually know how?
      05-29-2011, 01:01 PM   #12
300
Drives: E90
Yes I do actually know how
Basically read your NFRM/FRM. Then take the NETTODAT file and make a copy to compare from.
Now change the AE wert_06 or whatever it is and change it to wert_01 and recode the car.
Now read the module again and compare this NETTODAT file to the last.
You'll find 2 bytes (values) that changed.
Then you change them:
00 10 --> [0,0V]
55 05 --> [5,95V]
DD 05 --> [6,6V]
21 06 --> [6,9V]
10 09 --> [10,2V]
F4 09 --> [11,2V]
D7 0A --> [12,2V]
49 0B --> [12,7V]
8D 0B --> [13,0V]
BB 0B --> [13,2V]
FF 0B --> [13,5V]
2C 0C --> [13,7V]
38 0E --> [16,0V]
Save this NETTODAT and recode using the NETTODAT instead of the normal MAN file.
PM me if you'd like more help.
Be VERY careful upping the voltages.
Cheers
      05-29-2011, 03:49 PM   #13
matrix76
matrix76's Avatar
61
00 10 --> [0,0V]
55 05 --> [5,95V]
DD 05 --> [6,6V]
21 06 --> [6,9V]
10 09 --> [10,2V]
F4 09 --> [11,2V]
D7 0A --> [12,2V]
49 0B --> [12,7V]
8D 0B --> [13,0V]
BB 0B --> [13,2V]
FF 0B --> [13,5V]
2C 0C --> [13,7V]
38 0E --> [16,0V]
Cheers
Can you confirm that this" PWM_ANSTEUERUNG_RL_BL_1" is the actaul file in question that the "wert" is changed or do you know the specific file in question?
Brian
      05-29-2011, 04:07 PM   #14
300
Drives: E90
Yes those are the angel eyes.
      05-30-2011, 10:51 AM   #15
Toad335
32
Drives: LCI 335i
00 10 --> [0,0V]
55 05 --> [5,95V]
DD 05 --> [6,6V]
21 06 --> [6,9V]
10 09 --> [10,2V]
F4 09 --> [11,2V]
D7 0A --> [12,2V]
49 0B --> [12,7V]
8D 0B --> [13,0V]
BB 0B --> [13,2V]
FF 0B --> [13,5V]
2C 0C --> [13,7V]
38 0E --> [16,0V]
Cheers
Very interesting! Thanks for sharing the detailed response. Now off to do a little comparing to see if I can figure this out.
      05-31-2011, 12:01 AM   #16
tldoxmf87
tldoxmf87's Avatar
South Korea
40
Drives: e92 TiAg
This looks promising.
If someone can post if it really worked and a step by step guide, that would be great.
I get everything but am a little confused on 'Then you can change them: ... ... '.
Do we use the exact values listed on the post and ignore the 2 bytes that changed? Or is this something that would differ depending on values changed?
Also not really sure how to 'recode using the NETTODAT instead of the normal MAN file.'
E92 TiAg
      05-31-2011, 01:08 PM   #17
300
Drives: E90
The 2 bytes that change are just used to identify the string of numbers that show you it corresponds to the AE's.
Then replace the bytes that changed with the ones listed.
Then rather than using the FSW use "coapiCodeSqByNettoData".
      06-01-2011, 02:22 AM   #18
tldoxmf87
tldoxmf87's Avatar
South Korea
40
Drives: e92 TiAg
Thanks! I'll try it later this week when I have time!
E92 TiAg
      06-17-2011, 02:17 PM   #19
Rotary Rasp
Rotary Rasp's Avatar
241
Drives: 2009 E92 335i 6MT
did you get it to work?
      06-18-2011, 10:23 PM   #20
tldoxmf87
tldoxmf87's Avatar
South Korea
40
Drives: e92 TiAg
No I tried but failed.. because I don't know how to compare the NETTODAT.
The NETTODAT has hundreds of values so I'm not sure if I have to be looking at everything one by one to compare them..
I might try later again.
      06-23-2011, 11:39 AM   #21
Rotary Rasp
241
bummer
      06-24-2011, 05:38 PM   #22
GtiGyver
GtiGyver's Avatar
69
Drives: 2009 Space Grey E90 328i MT
Dude, use "beyond compare".
Search this Thread:
Advanced Search
