Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Coding Remotely?
      03-10-2011, 01:22 AM   #1
bmw325i
223
Drives: 2006 BMW 325i
Coding Remotely?
Hi I am in need of some coding but live nowhere near anyone skillful enough to do it so is it possible to code remotely through teamviewer or any other means what would I need obviously the cable. What I want done most importantly is an error cleared from when I disconnected a wire from my battery. Also I want the windows and sunroof to close when you hold the lock button and I'd like the foglights to turn on automatically if possible. Let me know if you can do any of this especially clearing the code. I am not expecting someone to do this for free so let me know how much you'd want for this job. Thanks
      03-11-2011, 01:54 PM   #2
bmw325i
223
Hi is this possible let me know so I can order the cable. I am willing to pay to have the work done the main thing I need is the error cleared.
      03-11-2011, 02:00 PM   #3
onebadmofo
onebadmofo's Avatar
346
Drives: 2008 E90 M3
If you get a laptop with Windows XP and a compatible cable I don't mind remoting in and helping you out.
What's the error exactly?
      03-11-2011, 03:09 PM   #4
bmw325i
223
I disconnected a wire on the battery and now the airbag and seat belt light came on I connected it but the error needs to be cleared. Does it have to be windows xp I have vista will that work.
      03-11-2011, 03:36 PM   #5
bmw325i
223
Would this cable work with my 06 e90 http://cgi.ebay.com/ebaymotors/VAG-K...#ht_6221wt_948
      03-12-2011, 12:03 PM   #6
woodpecka
woodpecka's Avatar
68
Drives: E91
removing error is pretty easy and not risky.
you can learn how to do it yourself
      03-12-2011, 12:37 PM   #7
bmw325i
223
Would you mind giving some detail on what I would have to do. Would the cable I linked to work and what program would I use?
      03-12-2011, 12:59 PM   #8
woodpecka
woodpecka's Avatar
68
Drives: E91
all is here: http://www.e90post.com/forums/showthread.php?t=451145
When installed, you have to run INPA, found the Airbag and removing the warning.
      03-12-2011, 02:10 PM   #9
bmw325i
223
Thanks I didn't know that would remove the error now I just need to find a cable all I need is kcan since I have an 06 right? Would the one I linked above work? Thanks again.
      03-12-2011, 03:27 PM   #10
woodpecka
woodpecka's Avatar
68
Drives: E91
BMW is not mentioned so good question. Maybe not.
      03-12-2011, 07:48 PM   #11
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
For me, I would just buy this one. http://www.one-stop-electronics.com/...&product_id=16
That's what everyone is using and majority of us don't have any issues with it. Start reading from post 277 if you want background info about the cable: http://www.e90post.com/forums/showth...451145&page=13
      03-13-2011, 03:41 AM   #12
bmw325i
223
Swell I don't see a point in spending 3 times as much when the cheaper cable will work just as good for me.
      03-13-2011, 09:46 AM   #13
woodpecka
woodpecka's Avatar
68
Drives: E91
Some serial cable are cheaper. (~30$)
FYI, you can offer 85$ and you will get the USB cable on ebay.
      03-13-2011, 05:21 PM   #14
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
Ok, if the cheaper cable will work for you then go buy it. Just hope you don't get any errors when you try to use it.
      03-13-2011, 09:26 PM   #15
orangedawg
31
Drives: 328xi
I'vew got an e90 build date 02/07 and the cheap k-line cable works just fine so far. Got a usb/serial cable from monoprice as well as my laptop doesn't have a serial port.
