Stuck Rotors
03-10-2011, 12:29 AM | #2 |
71
Rep 1,410
You can try to spray some WD40 to help loosen it up. But if you are replacing them (not turning them) then yes. Bang away with a hammer until they fall off. It's is the only way.
03-10-2011, 12:38 AM | #3 |
231
Rep 3,561
clean the hubs with brake cleaner to get all the rust off and use some anti sieze before installing new rotors to avoid the problem in the future.
you can use a hammer, but do it through a piece of wood so you're not hitting the metal directly. |
03-10-2011, 06:31 AM | #5 |
40
Rep 2,431
My speeding isn't the problem. It's the Slow Folks ahead of me that cause accidents!
03-10-2011, 07:02 AM | #6 |
253
Rep 7,089
Drives: '06 AW 330xi
Turn your hand brake off....
03-10-2011, 10:11 AM | #7 |
81
Rep 741
['13 X3 SGM] [20" XXR550's in Black Chrome] [Lamin-X Tails/Fogs] [M-Sport Rear] [FOX Exhaust][H&R Sport Springs][RaceChip Ultimate][BMS N55 Intake]
SOLD-['06 325i TiAg] [19" VMR VB3 HYPERBLACK] [Blacklines] [OEM Xenon Conversion] [35% Tint] [M-Tech Rear] [M-Tech Front] [Black Vinyl Roof] [Slotted/Drilled Rotors, Cool Carbon Pads] [PBX] |
03-10-2011, 11:16 AM | #8 |
54
Rep 373
Liberally soak the mounting bolt area and behind the rotor with PB Blaster. Your goal is to try and get it to flow between the rotor and the hub. Then let it sit a few hours to let the PB Blaster do its thing. Then hammer away.
F83 M4 convertible, F15 X5 xDrive35i
Previous: E93 335i, E36 328iC, E28 528e, E21 320i |
03-10-2011, 11:25 AM | #9 |
173
Rep 3,415
Which axle are you trying to remove the rotors from, front or rear?
Make sure you have removed the retaining bolt (and this will sound stupid) - remove the brake calipers and mounting brackets) If it is the front rotors, light tapping is all that should be needed. If it is the rear rotors, like dfriller said, TAKE THE PARKING BRAKE OFF, then you'll need a bit more force. What I use is a 18" long piece of closet wood dowel and a 2 or 3 lb sledge hammer. Keep taping around the rotor (you have to hit it in the place where the brake caliper resides, so you need to spin the rotor around) |
03-10-2011, 06:33 PM | #10 |
47
Rep 1,160
Rubber mallet
Monaco Blue 330xi - Terra Interior/6-MT/Sport/Premium/Cold/CSL's/M3 Spoiler Lip/Black Kidney's
