Need springs for my LCI e90
03-08-2011, 11:21 PM | #1 |
173
Rep 1,343
Drives: BMW M3 DCT
I am looking into lowering my car, I have a 2011 335 M sport. My first question is, if i lower my vehicle will i loose handling performance and ride comfort? I have sports suspension on my car and it rides perfect to me...
I have 19" rims running 235 35 19 in front and rear 265 30 19... What are my options? Thanks |
03-08-2011, 11:27 PM | #2 |
197
Rep 2,163
I'm going with the oem performance shocks from tischer and eibach pro springs. My tires are like yours at 235/35/19 and 260/30/19. How wide are your rims and offset?
03-08-2011, 11:42 PM | #3 |
173
Rep 1,343
Drives: BMW M3 DCT
- 19"x8.5" ET35mm Front 235/35/19
- 19"x9.5" ET33mm Rear 265/30/19 |
03-08-2011, 11:57 PM | #4 |
197
Rep 2,163
If you want a conservative drop with handling similar to the stock sport, I'd stick with eibach pro sport. If you want to go more aggressive, go with h&r sport.
03-09-2011, 12:03 AM | #5 |
173
Rep 1,343
Drives: BMW M3 DCT
Like these correct? http://www.**********s.com/Eibach-Pr...90-E92-E93.htm
Thanks for helping me to i really appreciate it. |
03-09-2011, 12:07 AM | #6 | |
197
Rep 2,163
03-09-2011, 01:04 AM | #7 |
406
Rep 3,879
The Eibach Prokit will be exactly what your looking for, and the ride will be very close to the aport ride you have now. And won't wear the OEM shocks that fast.
Or are you planning on swapping shocks also? |
03-09-2011, 01:17 AM | #8 |
173
Rep 1,343
Drives: BMW M3 DCT
Thanks, would i need to swap the shocks? How much would all that be?
03-09-2011, 01:21 AM | #9 |
406
Rep 3,879
You can't have too many miles on the OEM stuff if its a 2011, so they will last for a while. But with a shock upgrade normally ride comfort changes, koni yellow is a good option because they adjust. They are a little pricey though, and konis + springs runs very close to a coilover setup, so at that point its a choice between the 2 systems, what they offer, and your wants for the car.
03-09-2011, 01:36 AM | #10 |
173
Rep 1,343
Drives: BMW M3 DCT
Well my car has 2k miles on it. I plan on having it for three years MAX... Will springs alone last that long?
03-09-2011, 06:41 AM | #11 | |
208
Rep 3,175
As to your question, yes, you will impact the ride comfort and handling performance of your car and not necessarily for the better if you were to JUST put springs on. You need to pair a lowering spring with a shock better designed for the lower ride height and spring rate of the springs. Take a look at the BMW performance dampers from Tischer (they are a sponsor under the vendors suspension forum). The dampers will be moderately more stiff than your zsp shocks and they are designed to work with a slightly lower spring. The shocks are only $133 on close-out (retail for $800+). Inventory is running VERY low and once they are gone they are gone. Based on your needs (drop, improved handling performance, while maintaining some of the stock ride comfort) I would recommend pairing the performance dampers with the Eibach Pro Kit Springs. (I have this set up too) |
03-09-2011, 10:56 AM | #12 | |
173
Rep 1,343
Drives: BMW M3 DCT
Thanks! |
03-09-2011, 11:02 AM | #13 |
208
Rep 3,175
Yes they will work with your e90 lci. After confirming part numbers (pre lci vs lci) with Evan at Tischer the shocks are viturally the same, same part numbers except the pre lci rear shock is off by one digit and Evan couldn't tell me what that 1 digit meant. Based on this I purchased the performance shocks for my e90 lci.
03-09-2011, 11:15 AM | #14 |
47
Rep 583
sorry to budge in.... but I have a non sport suspension, can I get those BMW performance shocks (from tischer) + the eibach pro springs? Will I need anything else?
03-09-2011, 11:15 AM | #15 | |
173
Rep 1,343
Drives: BMW M3 DCT
I am going to order mine today! THANK YOU! |
03-09-2011, 11:31 AM | #16 |
375
Rep 17,017
With aftermarket springs, you are going to a firmer spring rate that will reduce roll and improve handling. You certainly won't lose control or handling by upgrading the springs.
03-09-2011, 11:50 AM | #17 |
406
Rep 3,879
03-09-2011, 12:06 PM | #18 |
208
Rep 3,175
03-09-2011, 12:14 PM | #19 | |
208
Rep 3,175
That said, I would say there are exceptions; the Eibach Pro Kit springs with a moderate drop have a spring rate closer to that of the zsp springs in which case they should peform better then others mentioned, albeit the zsp dampers are not engineered for the lower drop of the eibachs. |
03-09-2011, 12:21 PM | #20 | |
375
Rep 17,017
However, the upgrades he is considering are designed to improve the car's handling without ruining the balance that the car is designed to have from the factory. The Eibach Pro Kit and H&R Sport Springs are both options that would maintain this poise while still providing a substantial improvement in handling and reduction in body roll. |
03-09-2011, 12:25 PM | #21 | |
208
Rep 3,175
03-09-2011, 12:29 PM | #22 | |
375
Rep 17,017
