03-01-2011, 01:24 AM | #1 |
Supreme Allied Commander
3808
Rep 54,295
Drives: F80 M3
>>> HP Autowerks <<< aFe Stage 2 N54 Intake
Producing 14 max horsepower and 27 lbs. x ft. torque, this radically different Stage 2 sealed cold air intake system is engineered to let maximum air in while keeping engine heat out.this intake system smoothly directs increased air flow for improved volumetric efficiency and maximum performance. So effective is the design that Intake Air Temperature (IAT) at normal running speeds with this aFe intake system is 11 degrees lower than the factory intake. Easily accessible with a satin black powdercoated aluminum cover, an washable/reusable conical air filter is enclosed in a molded plastic housing and mounted on a oval intake tube that smoothly supplies maximum air to the twin turbos. The full effect of this system cannot be felt or tested on stationary dyno and can only be fully appreciated on the wide open highway.
We've decided to sweeten the pot even more! If you place your order with us, we will not only provide you with the discount on the aFe stg 2 intake with FREE SHIPPING, but we will also offer you one of the following: 2 FREE Bottles of Motul 600 Brake Fluid 10% off of Macht Schnell DP 20% off of Macht Schnell Air Scoops 20% off of HP Autowerks Adjustable Endlinks >>>>>>>>> Order Here: http://www.hpashop.com/product.sc?pr...categoryId=110 with FREE SHIPPING! Spoke with aFe and they are not in stock with NO eta of when they will ship. Last edited by HP Autosport; 03-03-2011 at 01:49 PM.. |
03-03-2011, 11:17 AM | #2 |
3808
Rep 54,295
Drives: F80 M3
If you place your order with us, we will not only provide you with the discount on the aFe stg 2 intake with FREE SHIPPING, but we will also offer you one of the following: 2 FREE Bottles of Motul 600 Brake Fluid 10% off of Macht Schnell DP 20% off of Macht Schnell Air Scoops 20% off of HP Autowerks Adjustable Endlinks Last edited by HP Autosport; 03-03-2011 at 01:50 PM.. |
12-16-2012, 11:43 PM | #6 |
3808
Rep 54,295
Drives: F80 M3
12-24-2012, 08:52 PM | #8 |
3808
Rep 54,295
Drives: F80 M3
