PSS9 front springs rubbing/grinding?
02-24-2011, 08:57 AM | #1 |
75
Rep 2,491
Drives: 991 C2S Guards Red
ISSUE RESOLVED 2/27 (edited below)
Just had my PSS9 coilovers put on Sunday. They feel amazing, however I was getting a strange vibration from the front wheels and went back to the installer (who is a certified BMW tech) and got it on the lift to check it out. It turns out the front springs, when compressed, are rubbing/grinding on themselves. I should have taken pics but my phone was dead... I will try to explain the best I can: ISSUE: On the bottom of the front springs, the very tips of the spring literally are 1mm (or less) away from the body of the spring, so when you hit bumps or simply turn the wheel the tips grind against the body slightly. The slight grind is quite a noticeable vibration. You can see the scratches on the blue coating where the tips have rubbed the coil above them. (picture below to illustrate) This seems like a complete design flaw but after searching it seems that no one has had this issue before. I bought them brand new off a forum member who never installed them so I can't really call Bilstein to complain. The tech is going to get the spring off and grind down the tips to get them farther away from the body, or at least grind down the tip so that it is angled instead of a 90 degree jagged tip that can grind so easily. EDIT: Resolved! The OEM parts that are used for the upper strut mount were never taken apart to be greased/lubed properly. We did grind the tips of the springs very slightly as well. Although it seems obvious in hindsight, the OEM parts were taken directly off the original and put onto the bilsteins yet they rubbed only with the bilsteins... anyways, I am very happy with the PSS9 setup, and would definitely get these again. They go SO LOW if you are looking for the slammed look, but the adjustable dampening is what I am looking forward to messing with in the future
991.1 C2S PDK, Guards Red | PDCC | Sport Chrono + | Clear Tail Lights | Alcantara Steering Wheel | HRE FF01 | TechArt Springs | Sport Exhaust
Previous: Porsche 997 Turbo 6MT, Atlas Gray | Cobb Stage 2 | HRE FF01 | Europipe Stg. 2 Exhaust | GMG LMS Rollbar | GT2 Exhaust Tips | Pagid RS-29 | Rennline Pedals | SSK 997.2 Track Car, heavily modded & E92 M3 DCT, still miss her daily & E92 335i heavily modded Last edited by RON1X; 02-28-2011 at 07:40 AM.. |
02-24-2011, 11:52 AM | #2 |
34
Rep 781
I would say that if you need to gring the spring to make it work you've got a problem and you shouldn't have to grind anything to make it work. I would call the manufacturer before you go altering the spring in any way. Also that blue coating is there to prevent corrosion, I wouldn't grind that. Good luck.
02-24-2011, 12:04 PM | #3 |
75
Rep 2,491
^thanks for the response. Trust me, I don't want to grind it but don't know any other options right now. I did talk with the East coast Bilstein rep this morning and he said I should not have to do that either, but he did say that wouldn't harm anything per se. I am going to get it back on the lift to snap pictures for him to determine what the issue is (although it seems pretty conclusive that the tip is rubbing the coil with the coating showing scratch marks...).
Previous: Porsche 997 Turbo 6MT, Atlas Gray | Cobb Stage 2 | HRE FF01 | Europipe Stg. 2 Exhaust | GMG LMS Rollbar | GT2 Exhaust Tips | Pagid RS-29 | Rennline Pedals | SSK 997.2 Track Car, heavily modded & E92 M3 DCT, still miss her daily & E92 335i heavily modded |
02-24-2011, 12:15 PM | #4 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Henry, sorry to hear about this. Hopefully it's nothing too serious. Do you think it could be due to the alignment (or lack thereof)?
02-24-2011, 12:28 PM | #5 | |
75
Rep 2,491
I was with David last night at his shop until 11, we just put some anti-seize around the base of the spring but it persisted, which is why we are thinking of grinding the tip of the spring down slightly. Talked with the Bilstein rep also. I am also starting to think the top of the spring isn't staying seated; it seems when you turn the wheel the spring is rotating against the frame causing rubbing. Whether it is just the spring grinding itself or a combination with the spring's movement (TBD), something is off. At least I know I have the best person looking into it... hopefully it will be settled this weekend. Will keep you posted
02-24-2011, 01:48 PM | #7 |
1821
Rep 5,337
Put a "thrust sheet" between the bottom of the spring and the spring perch to allow for some free movement/rotation of the spring as it compress/expand.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
02-24-2011, 03:03 PM | #8 | |
75
Rep 2,491
there is a soft plastic blue "washer" that sits above the perch in between the spring. I have put grease all over the area as well but nothing has worked...
Previous: Porsche 997 Turbo 6MT, Atlas Gray | Cobb Stage 2 | HRE FF01 | Europipe Stg. 2 Exhaust | GMG LMS Rollbar | GT2 Exhaust Tips | Pagid RS-29 | Rennline Pedals | SSK 997.2 Track Car, heavily modded & E92 M3 DCT, still miss her daily & E92 335i heavily modded Last edited by RON1X; 02-24-2011 at 03:10 PM.. |
02-25-2011, 12:21 PM | #9 | |
34
Rep 781
