Seriously Considering the Following Suspensions
02-23-2011, 01:45 PM | #1 |
193
Rep 3,469
EIBACH PRO SYSTEM: Tuned well as most owners say their car now handles like its on rails with a ride thats super smooth.
SONIC TUNING S1: Great adjustability both in height and damping with easy to use damping adjusters at the top of the each shock. Also, all reviews seem quite positive. MY QUESTIONS AND CONCERNS: EPS: With spring rates that are nearly identical to those of stock ZSP, will the handling not seem as good as the aging BMW Performance Pack that I have now with springs that are a little stronger? Will I be let down? I have about 60k miles on the BMW kit at this point and its certainly lost a step or two. S1: With spring rates of 450/500lbs is it too much for the street? I remember with my PSS9s that on the softer damping setting the car oscillated a bit on bumps since there was not enough damping force, but dialing up the damping to fix that and the ride became a bit hard and jarring. UGH, so much to consider, and I dont have nearly the income I had back then so I need this to be right the first time as swapping wont be an option for quite some time. Any thoughts?
2016 Alpine White M3 (gone)
2019 Alfa Romeo Guilia (Totaled) 2020 Car-less 😁 (no more) 2020 M340 |
02-23-2011, 03:25 PM | #5 | |
193
Rep 3,469
I always felt something was "off" with this setup from the day I put it in. It had attributes that the PSS9s didnt have. It was harsh, crashing, and had some bounce from the start, but it also only cost 900 at that time and PSS9s were 1700, so yea, it made sense.
02-23-2011, 03:39 PM | #6 | |
Lamininist
82
Rep 1,030
60k! You get around a bit.
Know what, I dont think any set up works in the long run Theres something fundamental about the way the 3 series underpinnings are designed that make all shocker/spring combo's feel compromised....We feel initial euphoria when we try something new and then not long after,.....hmm, thats not the answer I was looking for after all. Discuss BTW - How do you rate the Falken 912's on this car?? Quote:
02-23-2011, 03:47 PM | #7 | |
193
Rep 3,469
I was totally in love with the first set of 912's and didnt even look at other options when I needed new tires. Im not as happy with this second set. Its probably my car as I had M3 front tension rods which I no longer have. So now the 912's seems too mushy. It might also be the aging suspension too, there are so many variables as the car is aging.
02-23-2011, 03:49 PM | #8 |
193
Rep 3,469
Yea, Ive been concerned about that too, the ratio seems best at about 1:2 for this car, even 1:2.5.
02-23-2011, 03:54 PM | #9 | |
Lamininist
82
Rep 1,030
Shes getting close to retirement me thinks. Respect to the old girl.
As you say, having fiddled with so many variables, you kind of forget how the Maker intended it in the 1st place. I bet that if you went back to the complete bog stock set up (with normal tyres of course) you would think it feels quite nice. Cheers Quote:
02-23-2011, 04:03 PM | #10 | |
193
Rep 3,469
02-23-2011, 04:49 PM | #11 | |
photographer // designer
35
Rep 380
Don't go with "Taiwanese" Sonic Tuning coilovers. I used to have Function/Form coilovers on my Accord (also Taiwanese and built in the same factory), and the ride was terribly valved. Also, the shock lowering mount is an awful idea... it comes loose too easily, and it also makes it really hard to lower and raise the car due to having to turn the actual shock to do so. Look into Eibach Pro Street S or Suspension Techniques V1 coilovers... each can be found for around $900 or less and are built better, and they have better height adjustment mechanisms. I say that European-made parts should go on Euro cars and JDM or East Asian parts should go on JDM cars. |
02-23-2011, 04:59 PM | #12 |
106
Rep 1,428
i have the sport system plus and i like it allot, not much worse then zsp. it all depends on the roads you drive, my sport susp wasnt exactly comfortable. the best thing about the eibach kits are that you can buy the dampers separately, im like you i will change shocks and struts every 50k or so regardless.
02-24-2011, 07:01 AM | #13 | |
Hellafunctional
37
Rep 426
02-25-2011, 12:10 PM | #14 | |
193
Rep 3,469
03-02-2011, 12:00 AM | #15 | |
311
Rep 3,572
The spring rate is comfortable for daily driving (comparable to OEM sports) when you set it to mid range, and turn up the numbers during track days. This setup is really flexible and it's perfect for those that want a daily street/track setup. |
03-02-2011, 02:21 AM | #17 |
406
Rep 3,879
I will be installing these in my car this week
03-02-2011, 10:47 AM | #18 |
193
Rep 3,469
Cant wait to hear how it goes.
03-02-2011, 10:47 AM | #19 |
193
Rep 3,469
Im thinking of going back to those. Who was the vendor selling them for 1200?
03-02-2011, 11:29 AM | #20 |
202
Rep 2,740
03-02-2011, 02:26 PM | #21 |
158
Rep 1,288
Drives: 2014 435iX, FBO
I got Dinan Stage 3 - not sure what the rates are ... but I had to give them one of my Kidneys for them...
I had to go full soft on the shocks because I was getting a bit car sick with the lack of give. Now it is ok, but it is firm still... I was told to go with the subframe bushings if you increase springs. Doing that now so I'll let you know the diff. Stiff springs and soft bushings are not good apparently. Doing the LSD at the same time, looking forward to that. Fraggy, talk to Harold and get some swifts.... the guy has so much experience - he can help you with this. People rave about those. He also has a full range of stuff... I would go there - and keep your kidneys.
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
03-02-2011, 02:30 PM | #22 | |
202
Rep 2,740
If the Stage 3 was just springs and shocks then I'm pretty sure a set of H&R Sport springs paired with Koni Yellows or FSD would handle much better. I had the BMW Performance suspension and I am not that pleased with it, hence why I went with the PSS9. |
