New Ytest
Sign out
Bimmerpost
Login
BMW E39 5-Series Forum | 5Post.com
Go Back   BMW E39 5-Series Forum | 5Post.com > BMW 5-Series (E39) Forums (1995 - 2003) > General E39 Discussions
      02-23-2011, 12:13 AM   #1
brian95006
Drives: 98 540I
Exclamation Engine cuts out and ASC lights up and get a MAF circuit code
I have a 98 540i. The other day while driving, the cars engine cut out for only a split second. It was almost like I tapped the breaks quickly. It started to get worse (happen more often) and then noticed that the ASC light came on on the dash. When the car was idleing I opened the hood to see if the ASC cable was engaging when the car would miss/ cut out. The cable did not move so made me think it was something else causing the engine to cut out. The engine light eventually came on as well. I checked the code and got a code for a bad mass air flow circuit. Any idea's? Would a bad mass air flow sensor cause the ASC light to come and the car to cut out for a split second? Please help, I do not want to buy a new mass air flow sensor if that is not the issue.
      02-28-2011, 03:10 PM   #2
brian95006
Drives: 98 540I
It turned out to be the MAF. Thank you for everyone's help.
Tags
asc, engine cuts out, maf, mass air flow, miss fire
5post
