I think I have all the M3 parts needed for my E92 335i
02-16-2011, 02:27 PM | #1 |
422
Rep 4,499
Hi all,
If you don't know, I was in a car accident, if you want to know more about it here is the link to it: http://www.e90post.com/forums/showthread.php?t=488841 Anyways before the accident I was getting ready for the M3 suspension upgrade, and I am not going to let that accident stop me from doing this! Because I am sure it is repairable. So when I get her back from the shop I will get these installed and see how much it improved the handling. Here are pics of what I have so far, so if you see anything missing let me know and thanks.
Have BT Tool professional, will scan and clear codes on your BMW. And now I am able to code my 2011 335is and M4
Link to my M4 euro delivery! http://f80.bimmerpost.com/forums/sho....php?t=1006526 |
02-16-2011, 04:00 PM | #2 |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
damn, that's everything? Coilovers?
adjustable endlinks? factory? the rear sway bushings don't look like the factory M3 bushings. I just did the M3 sway bars install.
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
02-16-2011, 04:29 PM | #3 | |
422
Rep 4,499
The adjustable endlinks are form HP Autowerks (Harold) And the rest are OEM M3 parts, all of the numbers match the M3 and the ///M stamp is on everything. So I don't know what you put on your car but I don't think the BMW dealer I got the parts from would make there own M3 parts. Here is the link where I got them from: http://www.bmwpartssource.com/ and Patrick Casey gave me a wicked deal on the M3 parts as well. But thanks for the useful input.
02-17-2011, 10:49 AM | #4 |
246
Rep 3,441
02-17-2011, 12:49 PM | #6 |
422
Rep 4,499
02-17-2011, 01:18 PM | #7 |
39
Rep 517
can you list everything you have there? i'm a noob, and i am looking for mods that would help me create a better ride than stock.
i just ordered a set of bilstein coilovers. i'm wondering if there is anything else i can get, cause my convertible body tends to bend more than i like on steep decline/incline hills. from what it looks like farbmw, you are looking for a track set up, while i am looking for complete opposite. lowering while preserving (as much as possible) a soft competent ride only for street. any suggestions? |
02-17-2011, 02:34 PM | #8 | |
422
Rep 4,499
IMHO the bilsteins are great for a DD they fit like they was OEM and the ride on them is better then the sport suspension so I think you are going in the right direction there. Well here are the P/Ns I found, you can go on realoem.com and find them as well. M3 aluminum rear guide rods: 33322283547 (1) 33322283548 (1) M3 rear abs/bva tube: 34522283017 (2) M3 rear aluminum wishbone 33322283546 (1) 33322283545 (1) M3 Rear lower camber link: 37142283617 (1) 07119904116 (1) 07119902751 (1) 33322283885 (1) 33322283886 (1) 33306760349 (4) 33176760342 (2) 33522283638 (2) 33306786187 (2) 33302283616 (2) Front sway bar (1)31352283515 (2)31352283516 (2)31352283517 (2)31352283037 (1)31352283441 (4)31352283442 (4)07119904295 (4)33326768884 Rear sway bar (1)33552283655 (1)33552283709 (1)33552283710 (2)33552283714 (2)33556764428 (4)07119906077 (2)07119903931 (2)33326768884 RUBBER MOUNTING FRONT (2)33312283382 RUBBER MOUNTING REAR (2)33312283383 Left Wishbone link (1)31102283577 Right Wishbone link (1)31102283578 Left Tension link (1)31102283575 Right Tension link (1)31102283576 M3 Cross-brace: Ring, dome cross-brace, left (1)51617900821 Ring, dome cross-brace, right (1)51617900822 Strut brace (2)51618044553 Mount for strut brace (1)51618045860 StudM8X29 (2)51618046445 StudM8X32 (4)51717898374 Hex BoltM8X20-8.8ZNS3 (2)07119904401 ASA-Bolt with circlipM12X1.5X39 (1)07146954965 Torx boltM10X16-10.9- (2)07146963730 Hex nutM8 (6)51717895241 Self-locking collar nutM8-8 ZNS3 (6)31316769731 Covering cap (2)51617891281
02-17-2011, 03:13 PM | #10 | |
422
Rep 4,499
But I bought them off a forum member so I really got a good price for them.
02-17-2011, 03:43 PM | #11 |
39
Rep 517
hey far,
thanks for all that info. do you sugguest taht i get any of those things you listed? given what i am looking for? or all thsoe items you listed for tracking purposes only? sometimes i feel that my e93 chassis is flexing, anyway to add to teh comfort level of the pss9 with any of the above mentioned? |
02-17-2011, 03:54 PM | #12 | |
422
Rep 4,499
I am doing this for the tracking handling but it all depends how you want your car to feel and what you comfortable with.
02-17-2011, 04:50 PM | #13 |
246
Rep 3,441
undies,
get the CONVERTIBLE M3 sways as they are specific for the E93 and bigger.
02-17-2011, 06:36 PM | #14 |
169
Rep 12,680
Drives: like an asshole
Why no steering arm (#13) or trailing arms (#10) I may do the same conversion using the same exact parts u are (minus the camber links) but find myself wondering why the hell shouldn't I get all 5 links if I'm already down there. Just tryin to pick yours or whoever elses brain.
http://realoem.com/bmw/showparts.do?...16&hg=33&fg=30 |
02-18-2011, 07:37 AM | #15 | |
422
Rep 4,499
But I also know two forum member that put the hole M3 rear on there 335is'.
02-18-2011, 08:16 AM | #16 |
169
Rep 12,680
yea i read thiers as wells.
if any of the suspension gurus/people who have done this wanna chime in id appreciate it. i know tischer has all these parts grouped minus the steering rod and camber links. just really curious cause if im spending this amount of money i might as well do it right and get the parts. but if they arent as critical as the other and wouldnt make that much of a difference i could use the cash elsewhere. |
02-18-2011, 08:25 AM | #17 | |
422
Rep 4,499
Someone please chime in if they have a answer to his question.
02-19-2011, 08:57 AM | #18 |
169
Rep 12,680
i just asked my question in the mr 5 thread ill report back
02-19-2011, 12:03 PM | #19 |
422
Rep 4,499
02-19-2011, 03:55 PM | #20 |
169
Rep 12,680
Post 242 is where I start but still a great thread
http://www.e90post.com/forums/showthread.php?t=184925 |
02-19-2011, 04:06 PM | #21 | |
422
Rep 4,499
02-23-2011, 01:16 AM | #22 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Studs need to be exchanged for bolts for the M3 strut tower brace kit as you will find out during your install - The cowling will hit the top of the studs. You wil have a cowling cover either not seated or cracked if you force it.
Rear camber link verticle head light aim bracket is not correct. Just want to point out the two obvious incorrect parts for you before you start your installation. And you got way too many unnecessary hardware with your M3 anti roll bar kit as well. |
