Upgraded Sway Bars....big difference
02-14-2011, 11:33 AM | #1 |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
A little background on my car:
I had previously install KW V1 coilovers on my 07 335 and really liked the setup. But the more I drove the car I realized that something was off.; nothing major, but the car was twitchy and I attributed it to the very small rear sway bar. The 335 comes with a 26.5 mm front sway bar and a 13mm rear. The oem rear sway bar can be mistaken for a brake line; it’s tiny! I’ve seen Honda Accords with bigger rear sway bars! Anyway, I did some research and the aftermarket sway bars (Hotchkis and H&R) are really expensive so I started looking at the oem M3 sways. The M3 has a 26.5mm front sway bar and a 20mm rear sway bar. Those sizes are very close to the aftermarket sway bar kits. The bushings are also much stiffer than the stock 335 sway bar bushings due to their makeup which is rubber coated steel bearings. The front and rear sway bars, bushings and clamps run ~$310 before shipping from Faulkner BMW in Pa. Most aftermarket kits are near $400 or more. Part numbers can be found on realoem.com. I can post them here if anyone is interested as well. Also, the E90 M3 Convertible runs a 23.5 rear bar, but I did not want to go this extreme as I wanted to keep the car balanced. I noted this for anyone who is looking for something more extreme. The cost is the same as the non-convertible rear sway bar. Now to the install: The front bar is very straightforward and does not take much time (approx 45 mins). Why change the front when they are the same size you ask? Well, the stock 335 front sway bar has a taper in two spots and the M3 sway does not. The taper affects the bar’s affective rate. Also, the M3 bushings are rubber coated steel bearings, not just rubber bushings like the 335 bar uses. The rear sway bar is a giant m*thaf*ker. Basically you have to lower the entire rear subframe and exhaust to make room to fish the bigger M3 sway bar into place. Probably took 2.5 hours to do but could be done faster now because of lessons learned. Basically, any suspension work in the rear of the 335 is a PITA. Fitment for front and rear is perfect. Driving impressions: Wow! Much better, this is the way the car should have come from the factory. Huge improvement in the rear and the understeer is minimized. 7mm makes a noticeable difference. There is a bit more “road noise” but nothing that could be considered annoying. Overall, I’m really happy with this upgrade even though the install was draining. Here are some comparison pictures of the stock 335 rear sway bar and the stock M3 sway bar that replaced it.
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
02-14-2011, 11:40 AM | #2 |
663
Rep 26,878
Drives: 2-325 330 2-335 2-Z4 2-135 X5d
Nice!!
I needs sways so bad! |
02-14-2011, 04:34 PM | #6 |
106
Rep 1,428
that is a big difference, but keep in mind that there are other differences in the m3 over the 335 or any other e90 92 or 93. if you notice dinan does not offer rear bars that size, i think its because they try to keep the car safe and comfortable while providing an improved performance feel to justify their clients spending money. this is why i chose the eibach sways over m3, it keeps the bias the same while providing a stiffer suspension. not to mention if you stiffen up the rear too much without an lsd you are going to dramatically lose traction defeating the purpose of suspension "upgrades".
02-14-2011, 06:16 PM | #7 |
Moderator
618
Rep 10,855
Impressive that you DIY'd the rear!
Definitely need LSD with M3 rear sway. Also recommend M3 rear subframe bushings. Probably need alignment.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
02-14-2011, 06:37 PM | #8 | |||
246
Rep 3,441
The M3 set up is moderate and there is no dramatic lose of traction. The main issue to be concerned with in chosing sway bars is if the car will OVERSTEER more due to the larger bars (specifically the rear). This is, as I said, why I stayed away from the larger M3 convertible bar. Quote:
LSD is NOT needed, but I will definitely do the subframe bushings. Alignment is NOT needed as the lower control arms were not disconnected and the coilover settings never changed.
02-14-2011, 09:40 PM | #9 |
40
Rep 818
I recently upgraded to the 14 mm M-sport rear bar (leaving the front zsp), and it has done a lot to balance up the car.
03-10-2011, 09:29 AM | #10 |
246
Rep 3,441
Here is the links to the site I used to get the part numbers. Write down the part numbers then go to Faulkner BMWs site.
Note: You don't need the nuts. Use your existing hardware. Front Sway Bar http://www.realoem.com/bmw/showparts...04&hg=31&fg=10 Rear Sway Bar http://www.realoem.com/bmw/showparts...11&hg=33&fg=45
03-10-2011, 09:49 AM | #11 |
42
Rep 586
03-10-2011, 09:29 PM | #12 |
246
Rep 3,441
1mm thicker.....not that noticeable. If it comes with upgraded bushings that would be more noticeable.
03-10-2011, 09:45 PM | #13 | |
164
Rep 2,556
I'm considering the 14mm rear sway, instead of the M3 f/r bars, with my zsp springs and koni fsd's. What is your spring shock combo? Do you still drive on rft's? What difference do you feel going up from the 13mm bar? tia
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
03-11-2011, 07:16 AM | #14 | |||
40
Rep 818
Quite a bit flatter at back, seems balanced with the front now (stock zsp front bar), some freeway ramp curves were down-right scary before (now it's more like my E46 was.) The ride is about perfect, stiffer, but not too much -- stiffer sways also stiffen up the ride. I didn't want to be in the situation where I over-did the back, then I'd have to do the front, and now have a car more suited for the track than everyday driving. The only other bar I considered was the Eibach 15mm, but figured the 14mm was designed to work with my struts/stocks/springs combo. Last edited by AlanAZ; 03-11-2011 at 01:37 PM.. |
03-11-2011, 10:34 AM | #15 |
246
Rep 3,441
The shape will NOT be that different (if at all) seeing that it's coming from BMW. If you look at my pics you'll see the M3 bar is the exact same shape as the stock 335 bar.
You are most likely benefitting from the bushings. The Eibach rear sway is a nice comprimise between stock and the M3 bar.
03-11-2011, 01:15 PM | #16 | |
40
Rep 818
03-11-2011, 02:43 PM | #17 |
130
Rep 1,512
Swaybars have some of the biggest impact (and are some of the least expensive mods) on handling. I'm surprised it isn't the "go to" handling modification for more people.
Thanks for posting up the detailed review! |
03-11-2011, 03:36 PM | #19 | |
246
Rep 3,441
I would be interested to see photos I listed links to the part number above Here is the links to the site I used to get the part numbers. Write down the part numbers then go to Faulkner BMWs site. Note: You don't need the nuts. Use your existing hardware. Front Sway Bar http://www.realoem.com/bmw/showparts...04&hg=31&fg=10 Rear Sway Bar http://www.realoem.com/bmw/showparts...11&hg=33&fg=45
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser Last edited by bigdaddycane; 03-11-2011 at 05:31 PM.. |
03-12-2011, 08:55 PM | #21 | |
158
Rep 1,288
Drives: 2014 435iX, FBO
I am doing both now - I did do the Dinan rear bar to match the Stage 3.. I felt I had to stick with Dinan on the rear bar. If was to do this over, I would do the M3 bars and a setup from Harold with Swifts...but I didn't. I'll post up how my rear bar affects things when I get it on with the LSD (doing the subframe bushings at the same time). And ya, I spent way too much fn money... the Dinan rear bar along was $369 before shipping, taxes and duty . I might as well have given them a kidney...
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
03-12-2011, 09:42 PM | #22 |
13
Rep 377
better off saving your money and just changing the bushings..cost ya like 25 bucks for the m3 sway bar bushings..cause there isnt much of a difference at all between the sports package sway and m3 sway.just the bushings
