Eibach or H&R springs?
02-13-2011, 12:03 AM | #1 |
30
Rep 318
I've done some research on here and know that with the Eibach the car drops a little less than H&R. But is there any other differences? I am most likely going to combo the springs with some koni shocks(yellow or FSD). Pictures of cars with both springs would help alot. What about ride comfort? Thanks guys.
02-13-2011, 09:51 PM | #5 |
119
Rep 3,325
Drives: E90 335i LCI
Yes H&R will lower the most compared to eibach Race is the lowest and will slam your car, while sport will lower it, IMO perfectly for daily driving.
02-14-2011, 11:12 AM | #6 |
375
Rep 17,017
02-14-2011, 06:19 PM | #7 |
30
Rep 318
Sounds good. I think I will go with the h&r springs and maybe get that bmw performance suspension that is on clearance for $133. Then upgrade sway bars, and I think it should work.
02-14-2011, 06:55 PM | #8 |
13
Rep 344
I thought if you went with lower springs and the shocks offered in Tischer, you will get a pretty harsh ride. Anyone care to comment on ride quality with that setup?
02-14-2011, 06:58 PM | #9 |
30
Rep 318
02-14-2011, 08:06 PM | #11 |
208
Rep 3,175
Reports of harsh ride are only when the Tischer Performance shocks are paired with H&R's. They appear to work quite well with the Eibach Pro Kit springs.
02-14-2011, 11:12 PM | #12 |
13
Rep 344
The pro kit doesnt lower your car much though right? Maybe thats why it seems to work well since its almost at stock height.
02-15-2011, 06:24 AM | #14 | |
208
Rep 3,175
The performance shocks work well with the Eibach's because the Eibach's have a spring rate that is very close to that of the spring rate on the sports package. If you choose to pair a spring with a higher spring rate than that you will run the risk of compromising the ride quality. |
02-15-2011, 06:25 AM | #15 |
208
Rep 3,175
see 2nd paragraph above. It's a function of spring rates and how low the springs are. If the Sportlines have a higher spring rate and drop the car much lower than the Pro Kit springs I would venture to guess the ride will not be that good.
