Better than seafoam treatment???
02-11-2011, 04:43 PM | #2 |
202
Rep 2,740
I used a bottle of this, http://www.fastwrx.com/moencl.html
Motul Engine Cleaner on my car and there was a slight noticeable difference. |
02-11-2011, 06:53 PM | #3 | |
79
Rep 1,032
Where can you buy this thing in Canada (preferably Ottawa, ON)?
02-11-2011, 09:41 PM | #5 |
28
Rep 513
bmw durham is now offering a walnut valve cleaning treatment. this is supposed to have a connection to the manifold via a vacuum and suck walnuts through it to circulate and clean the valves.....maybe inquire about this, it's said to remove a lot of carbon deposits.
02-13-2011, 12:46 PM | #6 |
119
Rep 2,312
my understanding is that the only real way to get carbon deposits off is by hand...scrubbing.
I've done some research, and people who have opened it up said that using seafoam or whatever might take the top layer off...but won't touch the hard caked up deposits. You need mechanical intervention, |
02-13-2011, 09:00 PM | #7 | |
79
Rep 1,032
Wow, it's a blessing in disguise since I rarely drive my car in a stop and go traffic.
I did the seafoam back in November last year. I noticed improvements. However, I don't drive my car that often so only time can tell if the carbon built up is there.... Quote:
02-14-2011, 09:51 AM | #8 | |
1274
Rep 4,703
To clean valves you need seafoam, the walnut threatment, take it appart and hand scrub them or use some other cleaner that is injected via pressure / vacuum line. |
02-14-2011, 11:04 AM | #9 | |
21
Rep 495
"WINDING ROAD FOR 7 KM" ... l |
02-26-2011, 02:09 PM | #10 | |
21
Rep 495
1st - the SA told me about injector cleaning, as a possible solution to power loss. Described it a lot like the walnut cleaning: some chemicals added to the tank, and direct cleaning of the injectors/fuel rail - $150 2nd - when I went to book the service above, was told by another SA that no such direct injector cleaning was available. I didn't have time to pursue the issue that day. 3rd - call again about the $120 special - want to know what it actually includes: told (i think by SA #2) that is does not include "direct injector cleaning", but that is available at extra costs parts & labour because it requires the removal of some parts and replacement of gaskets. When asked: " so the price (normally $150) only involves pouring a litre of chemicals into my fuel tank ?" that seems outrageous even for BMW - the SA decided that it also included a compression test that can detect "injector leaks" , but no code reading. And from what I've read, you really want to change your oil shortly after using injector cleaning or seaform..but BMW has not mentioned this so far either. I think I need to contact a different shop and compare answers.
02-27-2011, 10:16 PM | #11 |
53
Rep 2,384
Drives: W211 E350 4M MkV GTI 987.2 S
To paraphrase 2kaccordocoupe, no fuel (Tier 1 or not), fuel additive, oil, or oil additive ever comes in contact with the top facing parts of intake valves in a direct injected engine. The fuel goes directly into the combustion chambers by-passing the intake valves. Only air goes pass those valves, much like in a diesel engine. You can't clean the top facing parts of your intake valves by using them. (Sorry to Shell V Power or similar Tier 1 fuel users who think the fuels they use are keeping the intake valves in their direct injected engines clean like in the pictures.) You either need something that goes into the intake air stream, or have to take apart the engine to clean the valves by scrubbing.
The deposit that appears on the top side of the valves comes from the PCV system. It is from fumes sucked in from the crankcase by the PCV, burnt off on top of the hot valves. The only way to prevent it is by maintaining your PCV system and don't let your rings wear out (if you somehow can).
07 E93 335i - Returned at lease end
09 W211 E350 4Matic Avant Garde - Blk/Blk, AMG pkg w/18". Sport Susp. F1 Asym. Debadged. 09 MkV GTI w/Leather & 18" Huffs. F1 Asym 10 987.2 S w/Leather sport seat, Sport Chrono, 19" Carrera S II wheels Last edited by halB; 02-27-2011 at 10:46 PM.. |
