car vibrates when cold
02-08-2011, 09:55 PM | #1 |
596
Rep 3,386
its really cold outside here and in the morning when i get in my car i get on the highway, i dont floor it or anything but for a few mins when the car is cold going about 60mph the steering wheel slightly vibrates. is this normal?
02-08-2011, 10:19 PM | #3 |
149
Rep 6,604
Drives: e92 335i
not normal
02-08-2011, 11:14 PM | #4 |
35
Rep 286
02-09-2011, 06:54 AM | #6 |
41
Rep 487
I've experienced that but just thought it was cold tires needing to be warmed up from sitting over night. It gets better once they've been driven on for a few minutes; in my situation. Otherwise, check balance/tire pressure.
02-09-2011, 07:34 AM | #7 |
Rep 219
If you're running summer tires you will get that but usually on for a few miles till they warm up. There's a flat spot until they warm up. But unless the freeway is right next to your driveway it may be something else like the aforementioned tire balance.
02-09-2011, 02:32 PM | #8 |
149
Rep 2,383
Maybe it's cold, do you leave it outside at night or do you let it sleep in the house? lol:
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
02-09-2011, 03:07 PM | #9 |
596
Rep 3,386
to the people that are saying it needs the tires balanced, i dont understand why after driving for a few minutes the vibration goes away? if the tires were out of balance wouldnt it always vibrate? and the highway is literally 15 seconds from my house.
02-09-2011, 03:24 PM | #10 |
58
Rep 665
It's flat spotting and yes, many, if not most performance tires will do that to some extent. The tires will develop a flat spot where they contact the ground for an extended period of time such as overnight. If the tires are warm, the flat spot will disappear almost immediately as soon as you start driving. If they're very cold, the rubber doesn't rebound as quickly and the flat spot won't disappear until the tire warms up a bit. Flat spotting is often more pronounced when the tire is under-inflated so check to see if one or more tires are low on air.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
02-09-2011, 03:29 PM | #11 |
494
Rep 1,922
Drives: 2021 G80 M3
I just noticed it last night on my 335i. went away very quickly tho.
'21 G80 M3
'11 E82 135i DCT (Gone but not forgotten) '08 E90 335i (Gone but not forgotten) |
02-09-2011, 03:34 PM | #12 |
43
Rep 364
Ice/Snow can build up inside of your rims. Happened to me and exact same feeling on the highway. Check it out. Knocked it loose and wallah! Good luck.
02-09-2011, 03:36 PM | #13 |
Rep 259
Make sure you don't have any snow/ice stuck in your wheels. I really bad vibration the other day - I had to pull over on the freeway to see what was going on. Sure enough, ice caked in the right front, throwing off its balance.
2000 Dodge Dakota 4.7
2007 335i 6MT |
02-09-2011, 03:54 PM | #14 |
253
Rep 7,089
Drives: '06 AW 330xi
+1 to the frozen ice in the wheels.
Also check your tire pressures. Fluctuating weather will cause your tires to lose pressure because of the expansion of moisture in the wheels. |
