Anyone replace their own air filter?
02-06-2011, 07:59 AM | #1 |
Rep 16
2007 328xi coupe non-turbo
Trying to replace the engine air filter myself, the bentley manual explains how ,but my question is do i have to disconnect the electrical connector to the mass airflow sensor to lift out the air box? Sure looks like I have to but does this connector just simply pull apart or is there a trick to it? Also ,will disconnecting it cause a fault code that must be cleared when finished? I`m thinking of changing the filter at 30K miles, the dashboard maintenance indicators don`t list the engine air filter as a maintenance item, will it suddenly pop-up at 45K? Thanks for everyones help. |
02-06-2011, 09:52 AM | #2 |
145
Rep 1,132
Yes disconnect the connector but be careful doing so, there is a small tab you must pry-push on to do so. If you don't start your car while its unplugged you shouldn't get any fault codes. Have fun!!
02-07-2011, 02:38 PM | #3 |
103
Rep 2,783
Here are the instructions which also shows you how to delete the charcoal filter http://www.e90post.com/forums/showthread.php?t=21590
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
