Brake light service reset problem
02-04-2011, 09:46 AM | #1 |
54
Rep 450
Hey guys I'm having a little problem.
I just replaced my rear brakes pads. Service light was indicating 500 KMs left so I decided to get it done. I did not replace the sensor because I was told by many garage that if it didn't touch, it will still be good, which sounds logic. My Sensor looked mint. So I replaced the pads and went ahead with the DIY to reset the service lights but for some random reason, instead of reseting to like 20,000 KMs in reset to "-----" and no, my front brake pads indicator and rear brake pads indicator go crazy when I start the car because they think it's below minimum now. I tried again and again to reset them but they always go back to "-----" instead of a mileage. How do I get fix this? Thanks |
02-07-2011, 11:16 AM | #3 | |
103
Rep 2,783
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
02-07-2011, 04:33 PM | #5 |
54
Rep 450
Yeah, after seeing how the sensor is made on these cars, I realized it was a mistake. So I went ahead and replaced the sensor and it still does the same thing. I tried resetting again and instead of giving me a mileage it only displays "----" and tells me that the pads are below minimum usage.
Now the weird part is why did it reset the front pads as well?! When I first tried resetting I selected REAR brake pads, why did it reset both? And now, with the new sensor, nothing has changed... Really weird. Tomorrow morning ill have the GT plugged on it and see if we can reset it with that. You guys have any other suggestions? Car still under warranty until 2000 KMs I have an appointment on Thursday but I don't want to be charged for any work since I don't feel it's my fault that the computer can't reset anymore, even after I changed the sensor. |
02-07-2011, 05:05 PM | #6 |
103
Rep 2,783
Got this from another poster: "I just got my car back from dealership, went in with break light on. They looked at the brakes and they were fine, tried to reset and to re-program the car, the light stayed on. Checked the circuit and it turned out a break sensor wire was broken."
02-07-2011, 06:33 PM | #7 | |
54
Rep 450
Well i dont see how the front could have broken but i guess well see on thursday what they find. |
02-24-2011, 06:08 PM | #8 |
296
Rep 2,687
same thing is happening to my car... sa tried to blame it on my aftermarket stuff but the tech said it need to replace the instrument cluster..
i also only went in for service for the rear pad... now both my front and rear is set at ----.... no milage till replace...
POSTED WITH APOLOGIES FOR POOR SPELLING, GRAMMAR AND SENTENCE STRUCTURE |
02-25-2011, 08:56 AM | #9 |
103
Rep 2,783
G-Bus, what is the update?
06-07-2011, 01:09 AM | #11 |
54
Rep 450
