02-03-2011, 10:25 AM | #1 |
437
Rep 2,747
DIY RPI Exhaust Using Jack Stands
DIY Intro:
50 Photos / 17steps / Post #1 Part I / Post #2 Part II / Post #3 Part III Since I have removed and installed the axle back exhaust about a dozen times, I figured it was time to do a DIY. This is photo heavy step by step DIY including some good tips. The DIY only includes instruction for the passenger side. The steps are exactly the same for the driver’s side. You may also notice that the RPI's are already on the car while it is being jacked up. For the purpose of the DIY, I put the passenger side OEM muffler back on after the car was off the ground. Hand Tools Used: 01. 3/8 ratchet 02. 3/8 13mm deep 03. 3/8 12mm shallow 04. 3/8 8mm deep 05. 3/8 8mm shallow 06. 3/8 2" extension 07. 3/8 4" extension 08. 1/4 ratchet 09. 1/4 13mm shallow 10. 1/4 8mm shallow 11. 1/4 3" extension 12. 13mm ratcheting combo wrench 13. Cordless 90 degree driver with 3/8 male adaptor 14. Graduated caliper Support Tools Used 1. 6 jack stands 2. 3 wheel chocks (4 would be better) 3. 4 wood blocks 4. Shop blanket (creature comfort ) 5. Low profile 3.5 ton jack Reference Material: From realoem.com From 2007 BMW TIS Step 1 Secure front wheels Step 2 Locate jack point #4 from the BMW TIS ( be careful around the rear diff ) Step 3 Jacking up the rear of the car. Go through the next three photos and read the tips before you do this step. lining up the jack jacked up with good alignment and not touching the rear diff cover Watch the front Step 4 Jack stand/wood block placement. (review the next two photos/tips) Tip Step 5 Locate the front jack point (BMW TIS #1) Step 6 Review the next three photos related to jacking up the front of the car Step 7 Front jack stand/wood block placement Step 8 Remove the rear diffuser. There are 8-8mm fasteners and 2-12mm caps
LINK TO 07 IR PHOTO JOURNAL:http://www.zpost.com/forums/showthread.php?t=1303735
LINK TO 06 IB MOD JOURNAL:http://www.zpost.com/forums/showthread.php?t=403119 Last edited by crfine88; 02-03-2011 at 12:07 PM.. |
02-03-2011, 10:25 AM | #2 |
437
Rep 2,747
DIY RPI Part II
Step 9
Mounting Location A Remove 13mm hardware and gasket ring. Once you do this the muffler will pivot up and down; the pivot points being mounting locations B & C Step 10 Mounting Location C Remove 13mm bolt. Once this bolt is removed, you will want to support the weight of the muffler as will only be hanging by mounting location B. Step 11 Mounting Location B Remove 13mm bolt. Read tip in second photo. Once this bolt is removed the muffler is no longer attached to the car. Step 12 Retain all OEM hardware for installation of the RPI exhaust except for the Mounting Location B 13mm bolt. A new shorter 13mm bolt is supplied by RPI
LINK TO 06 IB MOD JOURNAL:http://www.zpost.com/forums/showthread.php?t=403119 Last edited by crfine88; 02-03-2011 at 11:29 AM.. |
02-03-2011, 10:31 AM | #3 |
437
Rep 2,747
DIY RPI Part III
Step 13
Attach RPI muffler @ Mounting Locations B&C hand tight. Step 14 Attach RPI muffler @ Mounting Location A hand tight. Step 15 Fine adjustment for gap between muffler tips and rear bumper cover. This takes place while tightening the 13mm hardware @ mounting location A. There can be a lot of back and forth here until you get your desired gap. Step 16 Tighten 13mm bolts at Mounting Locations B&C Step 17 Fine adjustment for exhaust tip protrusion
LINK TO 06 IB MOD JOURNAL:http://www.zpost.com/forums/showthread.php?t=403119 Last edited by crfine88; 02-03-2011 at 12:03 PM.. |
02-03-2011, 12:10 PM | #4 |
Viper Driver
36
Rep 1,311
^chris, thanks for the superb pictorial writeup! i opted to go the lift route (a lot faster and convenient) and have since re-adjusted my exhaust tips since my initial install. what really helps is ur very last tip on exhaust tip protrusion. my left tips stick out ever so slightly more than my right ones, so i'm going to readjust the 8mm nuts just immediately below the rear bumper cover to fix this. however, i do notice my tips still stick out quite a fair bit more than urs do? it's protruding about 0.5 inches now.
this whole perfect placement thing is seriously a work of extensive patience and meticulous detail. i've opted to go visually with my alignment since i don't have access to a digital micrometer, but i'd say it's about perfect for my very particular human eye now. |
02-03-2011, 12:31 PM | #5 |
8061
Rep 18,788
Drives: BMW
Great DIY, even more awesome Z4M.
02-03-2011, 01:23 PM | #7 |
Dark Sider
127
Rep 1,777
Drives: 2008 Space Gray Z4MC
Awesome thread right here! Could of used this the first time I did a swap. After six or seven I'm an old pro. Had no idea about the moving rear cover though. Sweet!
[URL=http://imageshack.us/photo/my-images/153/071jt.jpg/]
2008 Space Grey M Coupe-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert settings |
02-03-2011, 01:24 PM | #8 |
55
Rep 844
Very awesome of you to do this writeup. The fact that you took the time to explain how to jack the car up properly is golden. This will be very useful when I change out my diff and tranny fluids.
Thanks again! |
02-04-2011, 10:03 AM | #12 |
41
Rep 1,855
Didn't know about the 3/8" play in the bumper. Will need to see if I can get my exhaust protrusion to look right with your tip. Thanks!
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust |
02-04-2011, 11:16 AM | #14 |
56
Rep 1,739
Drives: 2008 Z4MC
Mad props for taking the time for this DIY
02-04-2011, 04:42 PM | #15 |
Dog Listener
701
Rep 7,850
What a wonderful DIY with lots of great tips! I couldn't agree more on the jacking tips!
02-04-2011, 06:45 PM | #16 |
Bimmer Noob
30
Rep 564
Bookmarked! Very well done, very high caliber effort!
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing, AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges |
02-04-2011, 10:09 PM | #17 |
40
Rep 881
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
WOW awesome DIY! I didn't remove the diffuser for my install though. Probably would have been a lot easier on me if I did =P
02-07-2011, 06:39 AM | #18 | |||||||
437
Rep 2,747
Glad you found the write-up useful because that's what it's all about. Since gasket ring is round and the mufflers pivot on an axis, the lower the muffler hangs the further it protrudes from the bumber cover. If your muffler hang a little lower than mine, this may be why thye stick out further Thanks Tom Quote:
Yep, it can be done without rear diffuser removal. You just get better access around the bulky stock muffler with it romoved.
LINK TO 06 IB MOD JOURNAL:http://www.zpost.com/forums/showthread.php?t=403119 |
02-07-2011, 06:42 AM | #19 |
437
Rep 2,747
Thanks for all the feedback guys. It makes the efforts of doing the DIY all worth while.
LINK TO 06 IB MOD JOURNAL:http://www.zpost.com/forums/showthread.php?t=403119 Last edited by crfine88; 02-07-2011 at 09:09 AM.. |
02-07-2011, 09:49 AM | #20 |
28
Rep 1,110
solid work. more great input into the z community on your behalf
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 * '14 Jeep Grand Cherokee Overland Hemi... No more snow for the M! |
02-07-2011, 03:10 PM | #21 |
92
Rep 1,603
Drives: Imola Red Z4MC
your workspace for ur car is godlike
///M - Some Mods 'N Stuff
