335D Suspension Mods
02-01-2011, 08:44 PM | #1 |
11
Rep 42
Looking to lower my E90 335D with coilover, but couldn't find anything specific for "D". Do the 335D have the same suspension as 335I? Any input would be appreciated .
02-02-2011, 08:01 AM | #4 |
208
Rep 3,175
Same part numbers so spring rates are the same. Only difference being that the rear springs on the d the last digit of the part number is off by one number and Tischer did not know what that difference meant. e90 spring rates are only affected by the type of options selected for the car. Everything being equal between an i and d the suspensions components are the same with the exception of the last digit on the rear springs.
02-02-2011, 01:19 PM | #5 |
486
Rep 1,614
Thank you for that info, cssnms. I had been wondering if the spring rates in the front might be slightly different owing to the weight of the diesel block (I had expected it to weigh more), but this really makes things much more straightforward. I already own the 'old' performance suspension kit, just have to determine which set of springs to mate up with it. Thanks again!
02-02-2011, 02:33 PM | #8 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
I thought the fronts on the 335d were stiffer to accommodate the heavier engine? Or is that for the 535d? I remember hearing that somewhere.
02-02-2011, 03:08 PM | #9 | |
208
Rep 3,175
The d is a couple hundred pounds heavier, but not sure if all or most of the extra weight is coming from the engine. I would venture to guess that although the engine is likely heavier, the balance is made up between the d's exhaust system and rear differential, which leads me to believe that the extra weight is spread out pretty evenly. Again this is just a guess, I contacted BMW NA and they could not tell me how much the d's engine weighs by comparison with the i, but instead referred me to a dealer, as if they would know. Last edited by cssnms; 02-02-2011 at 03:17 PM.. |
02-02-2011, 03:15 PM | #10 | |
208
Rep 3,175
I initially bought the lowering perches from Supreme, but came to the realization that by themselves they just won't lower the car to my liking. So I sent them back and plan to pick up the Eibach Pro Kit springs and I am likely going to pair them with the Koni FSD's. |
02-02-2011, 03:29 PM | #11 | |
486
Rep 1,614
I've read lots of favorable things about the Eibach Pro Kit springs w/FSD's, so it sounds like you've got a very nice combo coming. Does your car have the sport suspension? I have the sport, and would be curious to see how your new setup compares. Good luck, and please update us when you're done. |
02-02-2011, 03:46 PM | #12 | |
208
Rep 3,175
I hope this set-up works, can't imagine it could be any worse then my OEM suspension. I don't have the sports pack, just the base OEM suspension, if you can imagine what that's like. Will keep you posted! |
02-02-2011, 06:59 PM | #13 |
11
Rep 42
According to H&R website, the part numbers of the springs are different between "d" and "i". But cup kit will work for both. ummmm, that's confusing
335i Sedan E90 2007-up* Sport Spring # 50490-4 Sport Cup Kit #31054-2 335d Sedan E90 2008-up* Sport Spring # 29187-5 Sport Cup Kit #31054-2 |
02-02-2011, 07:03 PM | #14 | |
208
Rep 3,175
02-02-2011, 07:07 PM | #15 | |
11
Rep 42
OK, will give them a call. |
02-03-2011, 01:23 PM | #17 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Depends on your budget. If you are after a custom coilover kit(damping and height adjustments with user select spring rates), the choices are AST and TCK, off of the shelf kits are your everyday Bilstein, KW's and etc.
02-03-2011, 04:02 PM | #18 | |
11
Rep 42
OK, just spoke to Robert@H&R, he confirmed that the spring rate on both set of springs they offer for the "d" and "i" are the same. So, everything that works for the "i" will also works for the "d", including cup kit and coilover. |
02-03-2011, 04:08 PM | #19 | |
3847
Rep 54,376
Drives: F80 M3
If anyone has a diesel and would like us to throw it on a corner balance scales send us a PM or email. |
02-03-2011, 04:42 PM | #20 | |
486
Rep 1,614
02-03-2011, 05:19 PM | #21 |
3847
Rep 54,376
Drives: F80 M3
Are you talking about a Swift sport lowering spring kit? If that is what you are asking, that is in the R&D, but I have no release date at this time.
02-03-2011, 07:27 PM | #22 |
Moderator
618
Rep 10,855
Hi Harold,
What a number of folks are interested in are springs made by Swift, that would be an alternative to OEM or BMW Performance (yellow) springs and could be used with BMW Performance dampers, Koni Yellows etc. Not necessarily a lowering kit, although I guess with the thinner diameter and hence greater range of travel a Swift spring would have to be a bit shorter unless the perch could be adjusted.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
