why is there big dips in so many n55 dynos?!?....answer inside
02-01-2011, 06:21 PM | #1 |
34
Rep 522
shockin330i started a thread about the torque dip in n55 a few days ago here:http://www.e90post.com/forums/showthread.php?t=482004
i speculated that it had to be a boost control issue and that the stock tune would spike boost on a dyno, (because it doesn't load the car like the real world does) then the DME pulls wastegate DC and/or closes the throttle blade to get the boost overrun under control , causing the big torque dip we see. Well i decided to test this theory of mine on a dyno and show the results. My car is a 2011 135i with the dual clutch trans (DCT) and has the following power mods (as of time of dynos): PROcede v5 DCT1-5maps Helix n55 FMIC AA axelback AR n55 catless DP HP autowerks air filter custom n55 charge pipe (for future meth bungs) Now, this is 1 run in map1 and 1 run in map 0 within minutes of each other: Here's the datalog from the map1 run: This is the datalog from the map0 run: Also note that, in the datalogs, CAN throttle and Throttle(pedal) are overlaid so that we can see when the DME is closing the throttle blade. So, as we can see from the data logs, on map1 the boost goes up as expected, wastegate DC goes up normally as expected for whats needed to get the small turbo to try to keep up and the throttle blade has no closings. But in the map0 run we can see that the boost does overshoot and the DME goes nuts trying to correct it, it drops wastegate DC by a ton and it also closes the throttle blade even down to 35% opening.... So there you have it! |
02-01-2011, 09:28 PM | #3 |
109
Rep 1,043
well done thanks for the info.
02-01-2011, 09:44 PM | #4 |
Rep 251
As long as it only does it on a stock car on the the dyno, I've got no problems. It DOES illustrate the wastegate PID issues (a la Shiv's explanation) very well though.
Just to be fair, Mike/Terry has also brought that up as an issue. Thanks for posting that up! |
02-01-2011, 09:45 PM | #5 |
654
Rep 8,801
sorry was mesmerized by
mr.5's "oil cooler" thread. so it's boost control issue under dyno situations. nothing traumatic to normal driving circumstances.
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) • KW clubsports • • • • • • • • • • 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue |
02-02-2011, 06:20 AM | #6 |
74
Rep 1,035
This is why I tell people to use a real loaded dyno, not crap unloaded dynojets. But have you logged it on the street to see if it is different?
02-02-2011, 06:27 AM | #7 |
151
Rep 1,809
So the N55 can't even be dynoed unless on a Mustang
By the way, do you see the dips on stock with no tune or are they always appearing on the Procede Stock map ? Maybe it's just a bug in the Procede bypass stuff. Not all values are 100% bypassed as far as I know. |
02-02-2011, 07:40 AM | #8 |
34
Rep 522
I'll post some street logs later today .
As far as I can tell almost every dyno that I've seen has the dip with the stock tune. There's a thread here that shows dyno runs of a car that gets flashed and the base runs were done on the stock tune (with the dip) and later on the flash (no dip) , so I would say is not procede related at all. |
02-02-2011, 07:57 AM | #9 |
102
Rep 3,460
6400 rpm, 10.5 psi, 93 percent duty cycle? You n55 guys are done untill single turbo upgrades come out. I am surprised bmw put such a shit turbo in there.
02-02-2011, 08:31 AM | #10 |
654
Rep 10,587
that is a shame, probably still an excellent street vehicle though.
02-02-2011, 10:53 AM | #12 |
361
Rep 1,060
02-02-2011, 11:05 AM | #13 |
Team Zissou
3065
Rep 10,197
02-02-2011, 11:35 AM | #14 |
1736
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
With the new maps I'm testing, we are 100% DC by 5500rpm
I'm still not 100% convinced the turbo is maxed out. Knowing BMW, i wouldn't be surprised if the wasegate rod is set super loose and can be tightened. Shiv |
02-02-2011, 12:19 PM | #15 |
310
Rep 15,745
This. BMW wouldnt have dumbed down the power THAT much. The turbine blade is less restrictive than one of the turbos on the N54, so it should be able to flow well.
02-02-2011, 12:27 PM | #16 |
151
Rep 1,809
It's truly disappointing. I really hope BMW will have a non-M twin-turbo I6 in the future, because when the time comes to get a new car I don't want to be without options.
02-02-2011, 12:34 PM | #17 |
102
Rep 3,460
I would be surprised, its pretty clear the turbo is out of steam, shame, but it is what it is. To drop 5psi and go up 50 percent in wgdc is a joke lol. Make you wonder where that turbo is on the map.
02-02-2011, 01:01 PM | #18 | |
654
Rep 10,587
god how these engines would love a turbo that is at 50%dc at 15psi at redline. I think the ECU would be like this
02-02-2011, 02:24 PM | #19 | ||
798
Rep 4,784
ERnie
2016 BSM/f80/ZCP |
02-02-2011, 02:45 PM | #20 |
798
Rep 4,784
Eh, I'd rather stay with 1. AWD MS is currently working on a turbo upgrade for the n55. Should be awesome!
ERnie
2016 BSM/f80/ZCP |
02-02-2011, 03:25 PM | #22 |
34
Rep 522
there's many other platforms that can't really hold allot of boost up top with the stock boost control hardware ( solenoid/s, wastegate/s , DV/s ,ect) but that doesn't mean "the end of the road".
I've worked on a bunch of mzd speed 3/6 (also DI engines) and you can't get shit out of the motorcycle sized turbo with the stock hardware...but put a GM boost control solenoid with the correct resistor/s to match the OEM voltage and you can get the tiny turbo to hold 15PSI to redline....or take Evos on stock turbo, same problem , but change the OEM solenoid and/or OEM wastegate and they hold 23PSI to redline. It might take some work but I'm sure we'll get more juice out of them. |
