Valvetronic motor- Can't remove. What tool to use?
01-31-2011, 01:00 PM | #1 |
Rep 19
I can't remove that doggone thing. I've tried 6mm star and reverse torx sockets and nothing on the 2 bolts that hold it in place. Has anyone had success in removing it? What tool specs did you use? Help pleassssssssssse!!!
02-03-2011, 07:33 AM | #2 |
555
Rep 1,244
Drives: 2013 F10 M5
I'll have to check out on my car, but external torx work just fine. I had to remove mine about 3 weeks ago to replace my valve cover gasket and replace some broken aluminum cover bolts.
And there's 3 bolts holding it in place, two on each side and one on the bottom (the bottom one is sideways). Just checked, you need an E8 socket for those bolts. |
