Oil Cooler Line Thermostat Question
01-30-2011, 11:36 PM | #1 |
Modder Raider
755
Rep 8,633
Drives: M3
I'm curious if anyone knows which line is the ouput to the oil cooler and which line is going from the oil cooler into the housing.
I'm about to install my new oil cooler and I want to make sure I install the lines correctly. I got the below pictures from Former Boosted's Stett OC article.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
01-31-2011, 01:15 AM | #2 |
49
Rep 469
Drives: BMW 16' M3
01-31-2011, 09:40 AM | #3 |
Modder Raider
755
Rep 8,633
Drives: M3
I know huh.
I think it's the right line because this is what connects to the top of the cooler. The left line connects to the bottom. Unless, oil flows into the bottom and flows to the top. I know water radiators work this way but I don't know about oil radiators.
01-31-2011, 10:12 AM | #4 |
324
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
Hope this helps
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
01-31-2011, 12:37 PM | #5 |
Modder Raider
755
Rep 8,633
Drives: M3
This doesn't help at all but thanks for trying.
This doesn't show which line is carrying the oil from the pump to the cooler and which line is sending the oil from the cooler back to the pump. This only shows that there are 2 lines going to the pump.
01-31-2011, 03:07 PM | #6 |
Modder Raider
755
Rep 8,633
Drives: M3
bump for an answer.
01-31-2011, 03:56 PM | #7 |
657
Rep 8,801
check out the PDF to this
LINK http://www.e90post.com/forums/showthread.php?t=70021 from 2007 eingine management PDF
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) • KW clubsports • • • • • • • • • • 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue Last edited by FrankiE90; 01-31-2011 at 04:16 PM.. |
01-31-2011, 04:23 PM | #8 | |
Modder Raider
755
Rep 8,633
Drives: M3
Thank you but that still doesn't tell me for sure what line is transfering oil to the cooler. I could ASSUME that it is the right line, but they may have only made the picture like that because it was easier to put in a picture.
I wish someone knew for sure. Quote:
01-31-2011, 04:35 PM | #9 | |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
It looks like the hotter oil comes out the driver side connector...
01-31-2011, 04:57 PM | #10 |
My X5d tows my spec miata to the track.
74
Rep 1,254
I'd get an IR thermometer and measure the temps of the lines at various places. The colder one is the oil coming back from the oil cooler. The thermometers are cheap at an auto parts store.
01-31-2011, 05:24 PM | #11 |
324
Rep 2,663
Or picking one up at home depot or lowes & returning it when your done.
01-31-2011, 05:55 PM | #12 | |
Modder Raider
755
Rep 8,633
Drives: M3
I think that the ultimate way to cool the oil is to have the oil flow from the top and then flow to the bottom. This is how all of the radiators are designed. Hot from the top. Cool at the bottom. Makes sense right? heat rises
01-31-2011, 05:57 PM | #13 | |
Modder Raider
755
Rep 8,633
Drives: M3
The return line or the incoming line?
01-31-2011, 07:18 PM | #14 | |
Modder Raider
755
Rep 8,633
Drives: M3
I don't think you can prime the pump by hand because the thermostat would need to be open and that only opens at around 200 degrees F. Someone with an oil cooler go for a long drive and let the oil temp get up to normal operating temp. Then go out and tell me which line is hotter. PLEASE?
01-31-2011, 07:55 PM | #15 | |
24
Rep 1,190
2011 VW GTI 4dr-6mt-Sunroof-Nav-Xenons
OLD: 08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD |
01-31-2011, 09:13 PM | #16 | |
Modder Raider
755
Rep 8,633
Drives: M3
This confirms what everyone is saying. The top line comes from the Driver's side. Thanks!!
02-01-2011, 06:35 PM | #17 |
114
Rep 2,428
I think this answers it pretty definitively; The passengers side is the feed, The drivers side line is the return.
These pics were taken within seconds of each other. One thing that's very strange though: the thermostat wasn't opened letting oil flow through to the oil cooler. The gauge temp was at 200*, and the oil cooler was as cold as the air. Although one must still assume the feed/return lines are as seen above, I actually wonder why/if they should be so different in temperature from just being connected to the thermostat housing. I'm very tempted to take out that spring and try to see if there's a way to have the thermostat open the entire time... Last edited by BrianMN; 02-01-2011 at 06:51 PM.. |
02-01-2011, 06:44 PM | #18 |
74
Rep 1,254
Rats. Beat me to it. I saw in the realoem catalog that one line is labeled return and the other (IIRC) flow. The return (cold) was on top.
02-01-2011, 06:51 PM | #19 |
114
Rep 2,428
I'm very tempted to take out that spring and try to see if there's a way to have the thermostat open the entire time... |
02-01-2011, 07:33 PM | #20 | ||
Modder Raider
755
Rep 8,633
Drives: M3
I should have thought about this. Quote:
This contradicts with the above and also contradicts with realOEM as well. RealOEM states that the right should be the flow (higher temp) and the left should be the return (lower temp). I'm curious if the IR thermometer was on the correct point because I know that the lazer is just a guide. hmmm.
02-01-2011, 07:43 PM | #21 | |
114
Rep 2,428
I'm positive the readings are accurate on the right hoses...I didn't just click once n done; rather looked/tested thoroughly and at different points, etc. There is one FLAW with this, and I'm thinking now it might be even bigger and more important: the thermostat had not opened. This test tonight might be worthless. Since I took a good rip sesh getting the oil to 220 (back to 200 at home) and saw the hoses were [very] warm, I figured the thermostat had been open and oil had gone through the cooler. After I posted, I went back out to feel the cooler, and both lines and cooler were cold. So one must assum the hoses must have gotten warm from simply being connected to the thermostat housing... That said, I don't see why the two lines would be so different in temp as there is no significant cooling going on between the thermostat venturis. Hmmmmjm |
02-01-2011, 08:08 PM | #22 |
324
Rep 2,663
I guess must ppl did it already. Well here are mines.
First one is Top at 185F Second one is Bottom at 175F
