Sorry for another boring question
01-29-2011, 06:46 PM | #1 |
57
Rep 737
Well its about tyres thats why I have already apologised
Ok I need to change the front pair as the outside shoulders are a bit worn out probably because of fast turning or could be an alignment issue. The problem is that the rears are michelin and I want same for the fronts but Michelin dont do them in manufacturers recommended size. The recommended size is 205-45-18 but Micheline only do that in 215-45-18. So it ok to have them or go for the recommended size. If I go for a wider one, would it not void any warranty incase something related goes wrong ? Thanks for your suggestions and advice. |
01-30-2011, 05:15 AM | #2 |
224
Rep 3,016
I'm not sure about the size change, but any reputable tyre dealer will tell you.
The other aspect to remember is that you should inform your insurance company. |
01-30-2011, 06:39 AM | #3 | |
The older I get, the faster I was
Rep 48
LCI 320d SE, M star 18" alloys, Msport bumpers and 700+miles per week
01-30-2011, 06:58 AM | #4 |
No Fear
13
Rep 278
Ring up ichelin UK and ask what sizes you can get away with, its around 5% of the overall aspect ratio I think, ask to speak to their sales dept., helpful when I rang.
01-31-2011, 03:50 AM | #5 |
57
Rep 737
01-31-2011, 04:00 AM | #6 |
18
Rep 442
Drives: E92 335i M Sport
If it's run flat tyres you have fitted, for some reason they always seem to wear on the outside shoulder. Best to simply replace all four tyres for non run flats. Problem solved!!
01-31-2011, 04:25 AM | #7 | |
6659
Rep 15,858
Same geometry, with non run-flats, wear is typically even. HighlandPete |
