M3 front wishbones/tension rods
01-28-2011, 03:53 PM | #1 |
16
Rep 226
I am thinking of upgrading to the M3 front control arms/tension rods. For those of you that changed to the M3 front control arms/tension rods, what were your alignment specs after you changed them so I can tell the shop after they've installed them. This is daily driver and I don't really track the car. I may go to an auto x every now and then. What settings would be best? I currently have Koni FSD shocks on stock sport springs and H&R front and rear sway bars on my car. Will I notice the difference with just changing the front to M3 components? Will the car be off balance since I'm not doing the rears yet? How much am I looking to spend on parts and labor to do this? Thanks.
01-29-2011, 03:52 PM | #2 | |
AutoXer
34
Rep 683
2009 135i, Alpine White, 6MT, M-Sport, iDrive, iPod/USB, Heated Seats, Premium Sound, BMW Assist
02-01-2011, 11:31 PM | #3 |
Fast In, Slow Out
40
Rep 586
Stick with a street set up for the toe. You can easily adjust the toe at the track and then change it back before you go home. Just ask some of the guys at the track for some help on how to do this.
: Ken
02-02-2011, 09:12 AM | #4 |
261
Rep 1,794
Drives: F30 328i M 6mt, E36 M3
I am very pleased with the swap, and have only been on the street with it.
The steering feel and turn in is awesome.
02-02-2011, 05:55 PM | #5 |
106
Rep 728
I have done the front only (not the rear). It's a very noticeable difference.
You'll read that swapping out for the M3 bits significantly reduces understeer. But I don't think people describe this enough, and after I installed it, I was actually slightly unsettled for the first few months until I got used to it. For me, understeer actually makes the car feel more planted, because it's less responsive. Prior to swapping out the M3 bits, I loved how my car felt. I did NOT understand how much understeer the car had, because I was doing well at the track against M3s, etc driven by people around the same intermediate skill level. I had also driven M3s often (from my friends), including attending the 1-day M-School with my buddy. At that time, I would say I liked how my pre-M3 bits swap car felt, more than the M3. In fact, my M3 buddy said the same cuz he likes cars that 'feel planted' as well. Keep in mind I was also not advanced enough at the time to really make full use of the car, and I believe this applies to 95% of the modded cars and users on this forum (just look at how empty our track sub-forum is). So when people say the M3 bits 'reduced understeer significantly', I didn't quite make the connection to the fact that the car now felt 'floatier'. Be sure to get your suspension readjusted. I had to tighten things up quite a bit, and keep in mind the car's 'character' will feel greatly different afterwards. So for me, the first few months I kinda questioned the mod, cuz really, street driving doesn't require that much unless you're....being reckless. The pre-mod understeer felt great for daily driving (especially and only if you have LSD!). My whole outlook changed the first time I tracked my car w/ the M3 bits. Omg, what a HUGE difference. Needless to say, I love it. I wish I read something like this before I got my mod, to mentally prepare me for the change...it's that significant Hope my impressions / feedback helps you. So this is not a negative review. Just trying to share my initial feeling after the mod so others won't be caught offguard if they don't understand what 'significantly reduces understeer' really means, and how it changes the driving characteristics and driving 'feel' of the car. EDIT: Oops, one last note, the M3 bits was my latest mod after everything else in my signature. So other people may feel differently depending on the order of their mods.
PROcede | AMS FMIC | AR Catless DPs | AR Oil Cooler | BMS DCI Wavetrac LSD | KW V3 w/ Swift Springs | M3 Front Suspension Last edited by orionredwing; 02-02-2011 at 06:12 PM.. |
02-03-2011, 01:13 PM | #6 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
As for labor, expect 1.5 to 2 hours on the install, plus alignment. |
03-14-2011, 11:57 PM | #7 | |
231
Rep 1,473
So if we toss on these M3 bits and lower the car at the same time, the factory alignment specs are still sufficient? Last edited by acdHQK713K; 03-15-2011 at 10:51 AM.. |
