Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Anyone just cut maybe a half turn off of spring coil?
      01-28-2011, 01:06 PM   #1
rigdowntex
Drives: 2016 M4
I've got a 2006 e90 330i with the sport suspension, 18 inch wheels and I know it's about .6 inches lower that the regular suspension or so I've read. Only want about 3/4 or so lower so was wondering if I could get away with just cutting off part of a coil turn and not ruin the ride or handling to any extent. I drive over a hundred miles 5 days a week and dodge deer, coons, porcupines, pigs, rodents, OK you get the picture.........RDT
      01-28-2011, 01:10 PM   #2
blacknbean
14
Drives: e92 335i 6MT
wow really? i wouldnt even do that on my honda let alone a bmw
      01-28-2011, 01:24 PM   #3
BMWsky
24
Drives: 335i
I have heard that isn't wise to do. Maybe someone can chime in to offer more advice on the matter.
      01-28-2011, 02:04 PM   #4
smack
smack's Avatar
Germany
34
Drives: BMW's/Flex Polishers
You cant be serious! Spend the money for a set of real springs!
      01-28-2011, 02:06 PM   #5
MassBimmer
MassBimmer's Avatar
No_Country
306
Drives: 2023 i4 M50
2009 BMW  [9.24]
Are you that cheap or that stupid? Cutting springs is probably the most dangerous thing you can do
      01-28-2011, 03:11 PM   #6
mike-y
just another bmw douche bag
195
Drives: 1.9L of fury
cutting the spring will change the spring rate. Although if you only cut half the coil, it probably won't change much. You can do this, and in theory it should work, but you might want to hit google, and read up about it before you attempt to diy.
I think you'd be better off looking into some of those lowering perches, which will lower the car slightly without changing the spring.
      01-28-2011, 03:21 PM   #7
Tee212
81
Drives: yes
2010 335  [8.00]
yup spring perch
      01-28-2011, 03:57 PM   #8
rigdowntex
Drives: 2016 M4
Hey thanks mike-y & tee212, that's why I asked. As for the massbimmer why waste the time with your remark. Oh wait i see, your a major general jackass, couldn't help it no doubt. I'll check into lowering perches......RDT
Hey I also was gonna say bite-me massbimmer but won't.
      01-28-2011, 04:04 PM   #9
Tee212
81
Drives: yes
2010 335  [8.00]
np, dont mind massbimmer...hes normally very cool and helpful in here
pm supreme powers, they should have them in stock. Keep in mind this is only for the fronts.
      01-28-2011, 04:16 PM   #10
rigdowntex
Drives: 2016 M4
OK, I'll take back the bite-me then for for the mass, hey I really do have a sense of humor but be sure I can dish it out too, tanks.........RDT
      01-28-2011, 05:02 PM   #11
Thumperx
88
Drives: 335I coupe
Originally Posted by Tee212 View Post
yup spring perch
+1
I would recommend looking into 3/8in perch drop or buy the correct set of springs before cutting springs.
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
      01-28-2011, 05:34 PM   #12
P4335i
12
Drives: 2010 Msport 335i
Dont' even consider cutting the springs. In addition to whats said about the spring rate it's also a safety concern. Back in the day I had a friend who cut the springs on his Geo Metro and they'd pop right off the perch because they no longer would seat correctly.
      01-28-2011, 05:57 PM   #13
rigdowntex
Drives: 2016 M4
Yeah after doing some lookin and research cutting them would be a bad idea from what i can tell now, thanks. I be learnin........RDT
      01-28-2011, 06:14 PM   #14
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
337
Drives: 2006 E90
I've cut springs on my '84 Toyota Supra and '98 Eclipse.....drove for about 7-8 years with no real problem........
The only issue I had with it was the ride was hella bouncing..........
Yeah.....spend a couple of hundred bucks and buy a new set of spring is probably the better way to go.......
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
