TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > Private Owners For Sale / Trade / Wanted > Suspension / Brakes / Chassis / Spacers > FS: Brake Bleeding tool for BMW, Audi, Porsche, etc., $15 shipped, NE-IL
      02-18-2007, 10:23 PM   #1
khnitz
Drives: 2005 VW GTI VR6, 6spd
BIMMERPOST / Classifieds
Asking Price:
None
Item Interest
I had this tool made a while back and still have some left to sell. I called it the Bleeder Buddy Basically, the tool attached to the brake fluid reservoir and then connects to a compressed air source at <~20psi.
So, by topping off the reservoir, attaching this tool and applying the pressure, you can go to the 4 corners of the car and force the old brake fluid out. I had to come up with SOMETHING, since I didn't always have a second person around to help pump the brakes.
The adapter is CNC-machined from aluminum, black anodized, and features a standard compressed air fitting. It also has a new rubber washer to seal the opening of the reservoir.
This should work on any ATE style brake fluid reservoir cap system. ABS systems may require additional steps to bleed through. I've personally used this on a 1981 VW Rabbit, 1989 Volvo 240, 1994 VW Golf, 1996 Golf, 1997 Jetta, and 1992 Audi 100 (this one had ABS...no problems). I've test-fit the cap onto Mercedes, BMW, Porsche, Saab, and other cars, too. I saw a similar tool at a Porsche dealer this past year - the Assenmacher TA18, that goes for around $30 online.
I have about 30 of these out in the field with no complaints. Main feedback is that the simplicity and compact size (easy to store) are plusses.
I'm asking $15 (shipped within the US) for each. This isn’t an ongoing business thing, just trying to clear out some stuff from the garage
Email to knitz@yahoo.com if interested.
      02-18-2007, 10:24 PM   #2
Chesmu
Chesmu's Avatar
89
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
you do have this patented, right?
"Teach the ignorant. Ignore the stupid."
      02-19-2007, 07:22 AM   #3
khnitz
Patent
I had looked into patenting the tool at one time with a friend who is a patent attorney. It would fail the "obviousness" test that is required of patents. Also, there are others offering similar items on the market that I have found, now (Assenmacher, a VW original tool part, etc.).
I've enjoyed using mine, and I've received nothing but positive feedback from those who've bought them. I'm just looking to clear out the last of the original batch of 100pcs that I had made up a few years ago.
      02-23-2007, 06:52 PM   #4
khnitz
As some have asked about the size of the cap to make sure it would fit their car, this tool was modeled after the ATE 51mm x 14mm brake fluid reservoir caps.
3 more sold this week, but there are still some available.
      03-10-2007, 10:55 AM   #5
khnitz
A few more have sold, but there are still tools available for those who are interested.
      03-10-2007, 09:49 PM   #6
s4iscool
26
Drives: 06 330i
any advantages over the Mityvac?ive been using that for years and its worked well
      03-11-2007, 10:51 AM   #7
khnitz
This is an alternative to something like the Mityvac. It would break down like this:
Bleeder Buddy -
advantages: small - stores easily, cheaper, allows another use for your air compressor
drawback: need an air compressor (small one is OK, though)
Mityvac -
advantages: draws its own vaccuum, so no air compressor needed
drawback: larger to store, more expensive (but still reasonable)
For both - Need to make sure that the brake flid reservoir does not draw down too far during the bleeding process.
So in summary, its a personal choice as to which is better for you. I like my Bleeder Buddy because it gives me another use for my air compressor. And, it works most like the factory tools for bleeding (by pressure, instead of vaccuum).
Thanks for the question! I'm just trying to get the last of these out of the garage :-)
      03-12-2007, 01:28 PM   #8
e30klassic
e30klassic's Avatar
25
Drives: Sport T-Silver E90
2006 328i  [0.00]
Question:
If this connected to an air compressor, will the PSI going to be too high ??
      03-12-2007, 02:26 PM   #9
s4iscool
26
Drives: 06 330i
lower the pressure then...not sure what you are asking :|
      03-12-2007, 04:23 PM   #10
e30klassic
e30klassic's Avatar
25
2006 328i  [0.00]
If its connected to the reservoir and directly fill pressure from the compressor how would you lower the pressure then?!
Not sure what part that you don't understand.
      04-20-2007, 01:31 PM   #11
khnitz
use the regulator on the line from the compressor
On my compressor, I use the regulator that is attached to it to control the pressure. I regulate it down to ~20psi. Others have been doing the same thing and it works well.
I've sold a few more over the past weeks, but still have some left.
