Min to Max after 1 qrt of oil
01-12-2011, 11:54 PM | #1 |
Rep 24
My car just got out the dealership after replacing 2 ignition coil and gasket. After drove for 2-3 miles, I got "!" on the console and when I checked the oil it shows MIN +1 qt. Since the dealer is closed, I stopped by a auto shop nearby and bought a 1qt of Mobile 1 0W-40 and fill it. After I started my car and waited until oil level show up it showed "OK" (and 1/4 level). I picked up my friend and went out to costco (around 5-6 miles of drive), refill the gasoline and I checked my oil level again, it MAX now!!.
Do you guy see any problem here? Is it ok to fill my car with Mobile 1 0W-40? |
01-12-2011, 11:57 PM | #2 |
Powered By 36DD
337
Rep 7,369
i've used Mobil 1 0W-40 and Castrol 0W-30 on all my oil changes.....every 5k miles with no issues.
by the way...my oil reading is always 3/4 full after every oil change(7 quarts)....never below or above.
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
01-13-2011, 09:26 AM | #4 |
Been there, wrecked that.
18
Rep 547
Since the difference between "min" and "max" is 1 quart as stated in your Owner's Manual...Is there an issue?
-Brian
~199K miles. I -still- don't fear my 335i. |
01-13-2011, 09:54 AM | #5 | |
103
Rep 2,783
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
