The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Africa > Infinity Speakers Upgrade
      01-12-2011, 05:29 AM   #1
Menno11
Member
Menno11's Avatar
South Africa
33
Drives: 320d
2005 320d  [0.00]
Feeling that the stock BMW E90 sound system was lacking in most aspects, I decided that a full speaker replacement was in order.
The reason for settling with Infinity was that they offered shallow mount speakers (specifically for the BMW’s shallow doors) and 2ohm impedance, which meant they can run off the stock HU power.
I have done the install piece by piece as I had the time and money, but have finally completed the entire install
The front speakers were a direct replacement of the 4” with the Infinity 42.9i
RMS power 50W, peak 100W running at 2ohm.
Magnet comparison
I am still manufacturing the adapter plates and will be fitting them behind the OEM grills again soon, but in the meantime I enjoy the look of the Infinity grill.
Following a dismal failure of trying to amplify the stock BMW underseat woofers, I replaced the burnt coil NOKIA 6.5” 35W speakers with Infinity 6.5” 5020CS (just the mid-woofer part)
RMS power 75W peak 225W at 4 ohm
Comparison of the inverted speakers and my home made adapter rings
The signal is tapped from the original speaker wire going to the underseat woofer
and routed to the boot to the Line out converter
where the pre-out signal is split to the mono-block amp and the 4 channel amp.
For the underseat woofers a 4 channel Infinity 475a amplifier was used
RMS power 4 x 75W at 4 ohm and a Starsound 2300 mono blck used to amplify the sub
RMS power 300W, peak (claimed 2300W)
In the boot I used a 12” 1260 Infinity sub-woofer SVC
RMS power 300W peak 1200W at 4 ohm
The sub was built into a ported 56 liter enclosure with the port venting through the arm rest into the cabin, thus creating a pressurized cabin.
The end result?
Well following endless tuning (unfortunately manual, no osiliscope ) the system plays the punchy kick drum notes perfectly through the underseat woofers, and the rolling base comes through impressively from the 12” sub for an all round much better musical experience. Better pics to follow with a full photo-shoot (any volunteers?)
      01-12-2011, 05:49 AM   #2
Jenich
South Africa
Drives: 2005 model E90 320D Sportspack
2005 E90 320D  [5.00]
Hey Menno, well done,
when you coming back to Johannesburg
      01-12-2011, 09:36 AM   #3
Menno11
Member
Menno11's Avatar
South Africa
33
Drives: 320d
2005 320d  [0.00]
I'm in Jhb next week Monday and Tuesday, but sleeping over in Potchefstroom
Search this Thread:
Advanced Search
