Break in period needed after oil change?
01-10-2011, 11:25 AM | #1 |
14
Rep 170
I did an oil and filter change about 2 weeks ago and I noticed that my gas mileage has been shitty since then.
I bought the oil from my dealer, so it should be the same as what was already in there, its a CPO car. So, does anyone know if after an oil change, a break in period is required for these cars or for the particular type of oil I used? It was the BMW Synthetic SAE 5w-40 type. |
01-10-2011, 08:05 PM | #3 |
14
Rep 170
01-10-2011, 08:24 PM | #4 |
148
Rep 2,932
My guess is it's the oil you used. If by Freehold you mean Freehold NJ then I would not use a 5w40 oil especially in the winter since that's a fairly thick oil. I would recommend 5w30 instead.
01-10-2011, 09:22 PM | #5 | |
14
Rep 170
But, now it seems like Im not getting the same gas mileage after changing the oil for the first time since I owned the car. It would make sense to assume that 5w-40 was already in the car when I bought it right? I'm going to switch to Mobile 1 regardless, but just wondering if theres a problem. I monitor how many miles I do on a full tank every week so this week will be no different. I guess I'll have to wait and see. |
01-11-2011, 09:17 AM | #6 | |
14
Rep 170
The only thing I did differently was add a bottle BMW Fuel Cleaner to the tank (had 1/8th of a tank of gas left) after the oil change. I filled the tires to correct presures, filled up on the same gas I always use, didnt drive any diffferently and I actually drove one day less than I normally do because I worked from home. So, everything is the same except I changed the oil and added that bottle of cleaner. If I had a bad injector, how would I know? |
01-11-2011, 10:21 AM | #7 |
124
Rep 5,627
Last time I checked, BMW synthetic 5w30 was actually cheaper from my dealer than Mobil1. And 5w30 Mobil1 is not approved by BMW for your car. I'm south of you and have used only BMW 5w30 for about 10 years in various BMWs with no problems whatsoever.
BTW, how are you calculating fuel mileage? If you are using the OBC, have you double checked it for accuracy? Do you reset it at each fillup? Are the driving conditions before & after the oil change the same? Lots of variables here. Tom |
01-11-2011, 12:43 PM | #8 | |
14
Rep 170
I meant Mobile 1 0w-40 is what Im going to use. I am using the OBC and have not checked it for accuracy. However, I drive the same amount of miles every week, more or less, and I am resetting it everytime I fill up. Yes, the driving conditions before and after the oil change are the same. All variables are basically the same, I didnt change anything except the oil and drive one day less. So, thats why I think the gas mileage is suffering a bit, it just doesnt add up. I guess I'll have to see what happens at the end of this week... |
01-17-2011, 11:06 AM | #9 |
149
Rep 6,604
Drives: e92 335i
none is needed
