How long is my oil good for?
01-08-2011, 06:33 PM | #1 |
149
Rep 3,552
Just need a quick responce. on a some what safe amount of time AFTER your oil change light come on.
my car has had its oil light / service light on for about a week now. and i mad an appointment for the 19th of this month. i should be ok right? synthetic should last much longer then the recommended life time right? |
01-08-2011, 06:34 PM | #2 |
369
Rep 8,693
Drives: 06 330i
assuming youve already dont 12-15k, 0
01-08-2011, 07:09 PM | #3 |
922
Rep 5,538
Well, there are different sides here.....
1st of all syn oil is usually good for 5-8k miles, not what BMW says. Will anything bad happen if you change per BMW 12-15k miles intervals, most likely no.....My father almost never changes oil or filter on his truck and the car has 165k miles (something that my 335 will never see with 7k oil changes).......if low oil light comes up, he just adds more oil..... Usually car enthusiasts change oil once in between BMW recommended intervals, or every 7-8k So to answer your question, yes, you will be ok for long time after oil change is needed. |
01-08-2011, 08:00 PM | #4 |
28
Rep 1,522
You are fine my friend, do what BMW says when it suits your needs, you will be fine, but if you don't like what BMW tells you, do whatever you want, you will be just as fine, as long as you read E90post and know what you are doing.
01-08-2011, 08:49 PM | #5 |
173
Rep 3,415
You'll be fine. I can't see why you need to wait till the 19th, it's just an oil change. Your car will run for an extremely long time if you follow the CBS oil change interval.
01-08-2011, 09:23 PM | #6 |
1911
Rep 13,104
Have you checked the level?
If you don't have so much money that this is a disposable car.
You should google Mike Miller BMW for the old school maintenance schedule. |
01-09-2011, 12:27 AM | #7 |
149
Rep 6,604
Drives: e92 335i
change it every 8000 miles
01-09-2011, 12:49 AM | #8 |
Corporate Hack
Rep 288
Oil doesn't magically go bad like an over ripe peach. Viscosity breaks down as the oil is used. As you drive an engine with inadequate oil, you simply have higher wear than if it had fresh oil. There is little difference in your oil 2 weeks ago when the service light was off than it is now with it on. So its not like your engine is going to go past its freshness date and catapult out of your engine bay because you put an extra week or two of driving on it.
That said, it would be better if you changed your oil more often than every 15,000 miles. The few used oil analysis I have seen posted on here seem to indicate that 7,500-10,000 miles is about the time it takes to use up your synthetic oil depending on your driving habits. So it makes sense, if you care about the longevity of your engine, to change the oil yourself between services.
New Car: 2008 335xi Coupe
Earlier Car: 2004 STi (got stolen) Earlier Earlier Car: 1995 Mustang GT (416 whp and a blown engine) Really Much Earlier Car: 1988 Mazda 626 TURBO |
01-09-2011, 01:12 AM | #9 |
1911
Rep 13,104
Carbon byproducts
There is a build up of combustion by products and metal . The filter will collect big particles up to the point its clogged then the engine will bypass the filter thats called blowby . The oil becomes burnt and all the additives are depleted, So the engine gets sanded in and acidic bath.
Then there is also sludge buildup from oil thats badly burnt and depleted. |
01-09-2011, 01:30 AM | #10 |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
lol... I change oil every 3K miles " to keep it fresh " as I have a heavy modded car, but for stock one 6 - 7k is enough.
01-09-2011, 06:38 AM | #12 | |
173
Rep 3,415
01-09-2011, 07:02 AM | #13 |
6659
Rep 15,858
I presume you guys are using the 'Longlife' (LL-04) synthetic oils in the US?
We are seeing service intervals around 20K miles/2-years in Europe, even in diesels. Not uncommon for the CBS to allow over 20k miles. Whether it is prudent to change earlier, is wide open to debate, but BMW will warranty engines, if we keep to that regime. HighlandPete |
01-09-2011, 07:06 AM | #14 |
1705
Rep 14,829
Forgetting about the light, I think 7500 (the ownership camp--the leasing camp no need to worry about oil, it's not your car, whenever it's convenient to bring it in). But the light (CBS) is often totally off when you have low mileage oil changes thrown in the mix. I got a free oil change at 6200 back in Aug., and then in Nov., the light went on and the dealership changed it again for free after less than 1500 miles. They really don't seem to care, as if BMW is paying and they're profiting.
01-09-2011, 07:13 AM | #15 |
1705
Rep 14,829
Actually my original service manager said about the same thing. He said probably much of our maintenance ideas are old school and unneeded, such as changing the oil at 1200 miles when new. But it's required for M cars, so if you own a 335, why not do it? Then he qualified, if you lease the car, who cares, just bring it in whenever you have a service warning, nothing more.
01-09-2011, 07:42 AM | #16 |
79
Rep 2,446
You must be joking of course, but 15K oil changes have been around for about 12 years (BMW and Porsche) and engines continue to be more and more lasting. There is no objective reason to change every 3K - complete waste unless you go to the track.
01-09-2011, 10:21 AM | #17 |
36
Rep 433
When Mobil 1 was first introduced, they bragged about 25k mile oil change intervals, I think a midway filter change was recommended. These synthetics are basically "lifetime" oils unless they get contaminated. I wouldn't sweat a couple of weeks but I wouldn't go to much further either.
01-09-2011, 10:55 AM | #18 |
1911
Rep 13,104
A passage from the "Motor Oil Bible"
http://www.carjunky.com/news/motor_oil/mom4.shtml
http://www.carbibles.com/engineoil_bible.html Amen Last edited by ctuna; 01-09-2011 at 11:09 AM.. |
01-09-2011, 11:16 AM | #19 |
209
Rep 1,712
01-12-2011, 05:08 AM | #20 | |
173
Rep 3,415
Pic of my engine valve train @ 106,000 miles w/ oil changes approximately every 17,000 miles... Last edited by ENINTY; 01-12-2011 at 05:15 AM.. |
01-21-2011, 03:19 PM | #22 | |
NHTSA Nazi
28
Rep 1,983
Oh, here is the definition of "blowby." Most everything else is wrong too. blow´by` (blō´bī`) n. 1. the leakage of gases from the combustion cylinder of an internal combustion engine between the piston and cylinder wall into the crankcase. |
