The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Is coolant Lifetime too?
      01-07-2011, 02:24 PM   #1
nhhiep
88
Drives: bmw
I just brought my 325i in at 60k and they only replaced engine oil and checked other stuffs. I asked about coolant and they said it's lifetime and the onboard computer doesn't show this item of when to replace it.
is that true? lifetime just like AT fluid?
by the way, they gave me a brand new 535 GT loaner... man, that thing is smooth, and roomy... so quiet compare to my car...but it feels big. and it looks ugly in person. it's 2011 and BMW still can't make the interior that looks not cheap. yep, a 5 series and still with a cheap looking interior.
      01-07-2011, 02:36 PM   #2
jaybird124
jaybird124's Avatar
156
Drives: 2017 M3 ZCP
Probably should replace the coolant at 80-100k.
There are several recommendations that say you should replace the water pump, hoses, and thermostat at that time too.
'17 M3 Imola Red/Carbonstructure Cloth, Competition, Lighting, 6MT
Retired: '93 325i |'99 Jeep Wrangler Sport |'06 330i Sport |'08 335i Sport |'08 328i Sport |'09 335d Sport
      01-07-2011, 02:39 PM   #3
Express
Express's Avatar
Israel
369
Drives: 06 330i
2006 BMW 330i  [8.30]
if my water pump went bad, can i assume i was given new coolant when this job was completed?
      01-07-2011, 03:00 PM   #4
VWtoBMW
VWtoBMW's Avatar
68
Drives: 2021 X5
I trust lifetime fluids like I trust the 15k mile oil change intervals that the CBS suggests.
2018 540d xDrive Carbon Black Metallic on Cognac leather. Spec'd out to the max
2017 Mercedes C43 AMG Coupe. Black on black
      01-07-2011, 03:13 PM   #5
StoneCold
13
Drives: BMW 2008 328i Coupe, Pro 02/08
bentley manual recommends every 4 years on coolant replaces.
      01-07-2011, 03:20 PM   #6
Bcube
Been there, wrecked that.
18
Drives: '07 E93 335i
AT fluid is not lifetime. BMW states 100K miles replenishment.
-Brian
~199K miles. I -still- don't fear my 335i.
      01-07-2011, 03:21 PM   #7
bill owen
Drives: 335d
I was advised by a couple of dealers that the antifreeze currently used is the same antifreeze BMW used when it recommended flushing and replacing the antifreeze every four years PRIOR to adopting the "No maintenance cost for four years" program.
Maybe the factory fill is different; or the compounds in the BMW dealer’s antifreeze jugs changed and the labels didn't; or maybe newer engines don't needed fresh antifreeze.......
Draw your own conclusion!
I elected to follow BMW's old recommendation....
Bill
      01-07-2011, 03:21 PM   #8
bumere90
Grozniy
177
Drives: Carless
every 100,000 miles or every 4 years.
      01-07-2011, 03:29 PM   #9
Bcube
18
For the E36/E46 models which have known cooling system issues. Recommendations for those models:
Water pump: 60K
Radiator: 100K
Hoses: 150K
Not enough data for E9X series to determine a trend of failed cooling components, so any recommendations at this time are just guesstimates... I obviously think 100,000 miles is too soon for these components.
-Brian
      01-07-2011, 03:48 PM   #10
Chriztofor
Chriztofor's Avatar
103
Drives: '06 325i and '13 X5
I don't trust BMW's lifetime BS. BMW contradicted themselves. On the Auto transmission it states, "Lifetime", but in their warranty booklet they state, "100,000 miles". Coolant like any other fluid/oil goes bad over time and mileage.Therefore for the hell of it I change the coolant every two years. Since antifreeze not only protects against freezing, but also lubricates the water-pump I will err on changing the fluid once every two years especially when the water-pump is a $500 part-only item.
Since the water-pump costs $500, I will wait until it dies. Just make sure you have towing insurance.
Correct.
Water pump: 60K
Like I said, for $500 I would not change it every 60k and I believe people on here had their pumps last to 100k. However, once the pump fails I would change the Thermostat too.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
      01-07-2011, 04:32 PM   #11
Tom K.
Tom K.'s Avatar
124
Drives: '07 328iT, '13 Boxster
Not quite true as my '03 Z4 4 year maintenance included a free coolant flush at the end of the period.
Since we're not hearing of many E90 cooling system problems, I'll probably have it done around 70k or so.
Tom
      01-07-2011, 06:08 PM   #12
MazdaFan
11
Drives: 2014 X1 xDrive 28i
There is a different type of environmentaly friendly coolant that lasts well over 100k, I suspect this is what BMW uses these days.
Don't trust what dealer recommends they obviously want to create business for themselves.
Some guys refer to Mr. x recommended old school maintenace schedule (which he has copyrighted BTW). This is ridiculus Mr. x just wants to make more money off of you. If you follow dealer recommended maintenance you have to spend additional 1k a year from your pocket not just for BMW even for a Kia. Just follow what the factory recommends.
      01-07-2011, 06:15 PM   #13
John 070
1705
Drives: 335i cpe
Coolant also prevents boiling as well. My friend's dad never could understand that. He used 100% antifreeze in all his cars thinking he was really protected to low temps. He actually made things worse--I told him no more than 70% but he wouldn't listen. And I was 14 when I gave him that advice.
      01-09-2011, 11:40 AM   #14
SCA
SCA's Avatar
565
Drives: Multiple BMWs
I recently paid a Center to perform a coolant flush on my '06 330. I brought a gallon of distilled water and an extra empty BMW coolant container with me. When I arrived at the Center I purchased a gallon of new BMW coolant and mixed it 50/50 in the two BMW containers. The tech performed the flush with the coolant I provided and I had the piece of mind that it was mixed properly with distilled water. I spoke with the tech afterwards and he confirmed that he would have mixed the new coolant with tap water.
BTW, service stated that the coolant is lifetime, but BMW parts does not sell a lifetime coolant nor is a part number listed for one. The fluid has not changed. The only changed noticed was the color & labeling of the container the coolant comes in.
