Replacing V-Belt
01-05-2011, 02:56 PM | #2 |
Been there, wrecked that.
18
Rep 547
I'm on the original. Inspected it over the holiday break while replacing my spark plugs. Belt is still in good shape.
-Brian
~199K miles. I -still- don't fear my 335i. |
01-05-2011, 03:20 PM | #3 |
550
Rep 6,563
I heard that when you replaced the v/drive belt, you should also replace the tension pulley as well because of the bearing wearing out. makes everything run smooth as butter...anyone disagreed?
under construction! |
01-05-2011, 09:36 PM | #4 |
40
Rep 818
The Bentley manual doesn't mention replacing the tension or idler pulleys. But I know on other cars it's often recommended.
It does not state a mileage to replace by, just to inspect. Last edited by AlanAZ; 01-06-2011 at 07:18 AM.. |
01-05-2011, 09:53 PM | #5 |
550
Rep 6,563
Good point, I forgot the idler pulley. But once you removed the belt, you can check these pulleys by spinning them and see if there are excessive play or noise with them. The bearing has grease that might dried up over time and it is good to just replace them at this time if they shows signs of wear.
01-06-2011, 12:43 AM | #7 |
103
Rep 2,783
^ You inspect the belt and see if there are any cracks. If so replace, if not then it's ok.
http://www.ehow.com/video_2327331_ty...belt-wear.html
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
01-06-2011, 08:10 AM | #8 |
173
Rep 3,415
I replaced mine at 100K. The belt is under $35 and takes 5 minutes to replace, probably the easist one I've ever done. The original belt was still in good shape after I inspected it, but I ordered a bunch of parts at 100K and had free shipping, so I figured why wait for it to start cracking and then pay $15 for shipping a $30 belt...
05-16-2014, 03:12 AM | #11 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
For what it's worth, Mike Miller recommends replacing OEM poly-ribbed serpentine belts every 60,000 miles and OEM V-belts every 30,000 miles.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
05-16-2014, 06:14 AM | #12 |
17315
Rep 18,737
The design and materials used in today's modern accessory-drive belts are far better than those belts that Mike Miller seems to be locked into in his old school maintenance plan. Modern belt construction has advanced to the point where they are now used in high-torque applications (i.e. motorcycle drive belts). I've replaced my belt twice at 100,000 mile intervals and both times the old belt looked almost as good as the new one I was replacing it with.
V-belts, which are rarely used on modern cars and not on any BMW for the last 20 years or so, have a higher replacement interval because the v-design endures more heat-generating friction than a ribbed-belt design. I think, based on my experience with inspection/replacement of many serpentine-style ribbed accessory drive belts, a steadfast 60,000 mile replacement interval is excessive. One should use the inspection method of looking for degrading cracks in the rib-side of the belt to determine replacement. |
05-16-2014, 07:37 PM | #13 | |
421
Rep 1,643
2007 E92 335i MT
05-17-2014, 05:01 PM | #14 |
289
Rep 864
Inspection Of V-belt
Today's new belts cant just be visually inspected with the bare eye and say they are good. You must have an inexpensive belt inspection tool ~ see ECSTUNING To properly inspect. However, why not just replace it around 70k and you will be glad you did. Like a 5 yr battery -- replace it around 4yrs instead of the hassle of finding yourself stranded.
