BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > New brakes, is all OEM brake/rotors for $610 the best bang for the buck?
      01-05-2011, 06:41 AM   #1
tracerit
139
Drives: 13 BRZ Limited 6MT
I'm still using the OEM brakes/rotors at 49k but I'm anticipating needing them replaced within the next year. I have no problems with the setup now. Sure the brake dust is there but I dont' mind it, gives that gunmetal look :P
I priced some other options out and they all come close to $600 for pads/rotors for all four corners. I've read good things about the OEM, but if there are better setups out there for the same price or lower, I'm all for it.
Also, do I need new sensors for all four corners? None of the sensors have been "activated" yet so would I be able to re-use them if I replace the brakes before they are?
      01-05-2011, 08:13 AM   #2
Ph0zenstone
Ph0zenstone's Avatar
325
Drives: 2018 530e X-Drive
that sounds like a lot of money...
      01-05-2011, 08:40 AM   #3
tracerit
139
really? that's how much it is for brakes/rotors/sensors from getbmwparts.com which usually carries the best price (for OEM i suppose).
      01-05-2011, 10:22 AM   #4
Bcube
Been there, wrecked that.
18
Drives: '07 E93 335i
Why the assumption that you need rotors? My first brake job was done by an Indy at 59K miles. Rotors were checked and measured and deemed within limits. So only the OEM pads and sensors were replaced.(With OEM replacements) I didn't change rotors till the second brake job at ~105K miles.
-Brian
~199K miles. I -still- don't fear my 335i.
      01-07-2011, 04:07 PM   #5
fisherbln
12
Drives: 2007 335i Coupe
$600 seems very reasonable for pads and rotors on all 4 corners. I agree with measuring the rotors though. If they aren't out of spec (or close) you can get away with not replacing them.
2007 335i SG Coupe
2009 128i AW
      01-07-2011, 04:51 PM   #6
BKV122
BKV122's Avatar
47
Drives: E90
2006 330xi  [9.50]
If u dont mind spending the extra money for the new rotors do it! I changed my front rotors when I did my pads just to have everything new. The rears i only changed the pads bc the dealer changed the rotors about 2 yrs ago
Monaco Blue 330xi - Terra Interior/6-MT/Sport/Premium/Cold/CSL's/M3 Spoiler Lip/Black Kidney's
      01-08-2011, 06:47 AM   #7
stressdoc
Moderator
stressdoc's Avatar
Dominica
618
Drives: BMW i8; Toy 4runner TRD pro
I prefer to change rotors with new pads. I like the alu hat front rotors from the Z4is for only $30 more per.
      01-08-2011, 09:25 AM   #8
JoeyFiasco
JoeyFiasco's Avatar
22
Drives: '09 Coupe
you're done a lot of miles, know anybody else with such high mileage?
      01-08-2011, 01:44 PM   #9
e90pilot
Freight Dawg
e90pilot's Avatar
104
Drives: E90 325i
Almost 150k here! My fronts lasted 80k but the rotors were done for because I let the pad ware to the back plate.... oops. Rears lasted 50k (pads only) because the cruise control only uses the rear brakes and I use it a lot in hilly areas. Second set of rears lasted all the way 'til 130k. I'm about to replace the fronts again. The computer says 5400mi to go.
Bcube has a 335 and I am thoroughly impressed. You must have found a gem! Hold on to that car becaue they're few and far between. I heard if you drive 335s like you stole them they fair a bit better.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors
      01-13-2011, 01:54 PM   #10
Anthony@BimmerBrakes
Anthony@BimmerBrakes's Avatar
Drives: 05 330i
If you haven't tripped the Brake Light. You wont need to replace the Sensors. You would be able to reuse them $600 for OEM Setup is not a Bad Deal at all. As there is other options for alittle cheaper if you are looking for that route for the Same or Better Performance.
