Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Weird sound after install axle back exhaust ...
      01-04-2011, 01:27 AM   #1
skate0518
57
Drives: E46-E85-E92-F82
Just weld an axle back exhaust onto my e92 N55 Lci But when driving speed over 20 miles, it start making a high pitch static noise. I can't figure out what is causing this sound. Anybody know what could be the problem & any way to fix ?
      01-04-2011, 11:21 AM   #2
Bodie217
Bodie217's Avatar
92
Drives: '10 135i, '14 WRX, '14 Sequoia
can you post a video or sound clip?
Only thing that comes to mind is a shotty weld causing turbulence or an exhaust leak.
I'd also say it could be packaging material inside the new exhaust piping, but I'd hope the installer would've checked the exhaust before installing
-2010 BMW 135i - Titanium Silver - Procede v3/ETS 5" IC/AR Catless DP>N54mid>Berk Race/BMS OCC/VRSF Turbo Inlets & CP/SP rotors/Pagid RS29/APEX ARC8/Ohlins DFV/M3 Full Suspension and Bushings/Wavetrac LSD // 395rwhp/469rwtq on 91oct
-2014 Toyota Sequoia Platinum - Overlander
      01-04-2011, 11:36 AM   #3
Forcefed3
No_Country
127
Drives: 2008 335i
2008 335i  [1.00]
What kind? Post a video.
      01-04-2011, 11:42 AM   #4
Kevin@AKMotorwerk
Kevin@AKMotorwerk's Avatar
290
Drives: THE GUY YOU LOVE TO HATE
exhaust leak, loose clamp, or the exhaust is hitting something and vibrating against it
      01-04-2011, 11:44 AM   #5
Forcefed3
No_Country
127
Drives: 2008 335i
2008 335i  [1.00]
+1
Thats all it could be really.
      01-04-2011, 02:36 PM   #6
skate0518
57
THX guys , I think it might be exhaust leak ! I will go check it out and post video if i can.
      01-04-2011, 05:15 PM   #7
skate0518
57
Just back from shop, they said the exhaust is fine and the weld is fine too. They said our car doesn't come with quality x pipe & no resonators, which is bad and suggest me to custom one .... but they have no idea what is causing the high pitch, like radio frequency type of annoying noise(the tone will vary depend on speed). Now after driving for 15 mins, i am having serious headache. That noise is killing me .... Where should i go and have some real "pro" to check out for me ?
      01-04-2011, 08:01 PM   #8
NiVeDh
NiVeDh's Avatar
422
Drives: '08 E90 335i, '99 E36 M3
Check to make sure the exhaust isn't rubbing on anything, like the heat shielding material.
      01-04-2011, 08:15 PM   #9
skate0518
57
Checked ... nth is rubbing or ticking ... only when rev up, it comes on ! won't notice it when stationary. Geez .... hope back to stock is not the "only" way ...
      01-04-2011, 11:05 PM   #10
Bodie217
Bodie217's Avatar
92
What axle back exhaust did you install?
Very shocking that the exhaust shop who did the work couldn't figure out what was making the noise...
Posting a video will help a lot.
      01-04-2011, 11:09 PM   #11
Bodie217
Bodie217's Avatar
92
Does the high pitch noise sound like this?
      01-05-2011, 04:22 AM   #12
skate0518
57
no I am sure its not Turbo making that sound, its like the air flow that is causing it because when i hit it over 5k rpm, it actually went away but once the rpm drop around 2k-4k it comes up .... I will try video it TMR but not sure if camera can capture it.
      01-05-2011, 06:33 PM   #13
skate0518
57
from 00:34 to the end that noise is clearly there ...
