TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > What are the best n55 procede settings to use??
      01-02-2011, 01:27 PM   #1
e92sport
38
Drives: black e92 sport
I just installed my procede on my n55 a few days ago. Car rides great and has had zero errors or problems. I wanted to know whats are the best settings to use that would achieve the most gains on a bone stock n55 with an hp autowerks drop in filter??? Are you guys using map 1 or 2? Have you adjusted any of the settings that would actually help?
      01-02-2011, 01:40 PM   #2
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
Don't do anything. The whole point of autotune on the Procede is that you don't need to dial anything in. When conditions allow, there will be less ignition retard and more boost, and when conditions are less favorable, the Procede will catch that and make the appropriate adjustments as well.
E90 LCI N54 6AT
      01-02-2011, 01:49 PM   #3
e92sport
38
Yes but both map 1 and map 2 have autotuning... I read that map 2 uses 1 psi more of boost??
      01-02-2011, 01:58 PM   #4
enrita
enrita's Avatar
Sweden
159
Drives: 335i - Big turbos
You can set whatever boost you want on both map 1 and 2. Just use map 1 as a low boost map and map 2 more aggressive.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      01-02-2011, 02:08 PM   #5
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
map 2 STARTS on 1 psi more boost. Your map 1 will reach the same boost if conditions allow, just as map 2 will dial down if they don't.
E90 LCI N54 6AT
      01-02-2011, 03:30 PM   #6
shockin330i
shockin330i's Avatar
798
Drives: 2016 ZCP M3
No it won't. It has a "max boost" 1psi less. Map one will not auto tune anything over 13psi and map 2 will not auto tune anything over 14 psi. That is unless you change the max setting like I did. I set my max to 14.5psi so my car is autotuning at 14.3. But shiv doesn't think its a good idea.
Heres a thread I started for all us n55 procede users
http://www.e90post.com/forums/showth...ht=n55+procede
ERnie
2016 BSM/f80/ZCP
      01-02-2011, 04:50 PM   #7
e92sport
38
Awesome, thanks
      01-02-2011, 05:17 PM   #8
e92sport
38
Would I lose my auto tune settings with v4 if I switch maps??
      01-02-2011, 05:49 PM   #9
black e
black e's Avatar
34
Drives: DCT N55 135I
yes
      01-02-2011, 07:24 PM   #10
shockin330i
798
Drives: 2016 ZCP M3
Yes, but nothing a few 3rd gear pulls cant change...
ERnie
2016 BSM/f80/ZCP
Search this Thread:
Advanced Search
