01-02-2011, 09:49 AM | #3 |
17
Rep 242
It is the auto hold feature that keeps the parking brake on as you release the brakes until you push on the accelerator (up to a maximum of about 5 seconds). This way, you can start on slopes without backing up when you release the brakes. I tried it on the X6 and I found I could not get used to it: I like releasing the brakes myself. But I have not tried in on the X3 yet... Here's hoping it is as much improved as everything else.
01-02-2011, 09:06 PM | #4 | |
Rep 23
01-02-2011, 10:09 PM | #5 |
Rep 43
Didn't realize it's only good for about 5 seconds. Good to know before I tried it at a red light while reaching into the back for something!
01-02-2011, 11:24 PM | #6 | |
17
Rep 242
Apologies! |
01-12-2011, 09:45 AM | #7 |
45
Rep 1,876
Used it during a test drive and it held seemingly indefinitely. The dealer described it as a "hill hold" function (though I thought BMW steptronics did that automatically, so confused a bit there) but also more as a function for stop and go traffic. Need only use accelerator for short moves and the Auto H function stops and holds you between moves. Don't know if I can get used to that, but it worked on the lot . . .
02-06-2011, 09:12 PM | #9 |
45
Rep 1,876
+1 re acer's comments; wasn't sure at first, but after 3 days I think I like the feature. Was a bit apprehensive at first sitting a stop lights and such, but the system held consistently and I realized that if it let go (no reason to think it would) it would be a simple thing to get my foot to the brake. Once I became confident in the system, it produced even smoother take-away from stop (for passenger comfort) than switching foot from break and onto gas and pressing down.
02-07-2011, 10:43 AM | #10 |
685
Rep 6,845
Drives: 2018 Audi RS5 coupe
by default is it on or off?
05-11-2019, 10:32 AM | #11 |
Rep 5
Does anyone know if autostart / stop turns off when using auto hold? My 2017 x5 has both of these features and I don't belive the auto start stop works...
05-11-2019, 05:47 PM | #13 |
105
Rep 253
They should rename it to "drive-thru" mode...
slowblackx3f2569.00 |
05-12-2019, 11:10 AM | #14 |
1908
Rep 5,102
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
05-12-2019, 05:30 PM | #15 |
877
Rep 2,542
Drives: Z4MC-X3-35i-525i, Corrado G60
slowblackx3f2569.00 BMWZ41908.00 |
05-13-2019, 03:28 AM | #16 |
Rep 28
People read your manual but just in case this is to difficult: the "auto h"button is to select the automatic handbrake function on. Instead of you using the handbrake button anytime you stop it instantly applies the handbrake and release's when you depress the accelerator. there is no time limit, it is not a specific hill start option it is just an auto handbrake. The only down / upside to it dependent on your point of view is it must be selected on every time you switch the car on.
scostu1621.00 |
05-13-2019, 10:07 AM | #17 | |
430
Rep 2,524
Bonus trick: you can also just pull up on the E Brake while the car is stationary and in Drive, and it will Auto Hold for you one time (you don't need to press the Auto H button) |
01-26-2023, 12:47 AM | #18 |
Rep 1
AUTO/H on my BMW X6 is an electric parking brake! Best used when you stop at Red lights just press the AUTO/H button (you will see a green message in your dashboard). NO need to put gear in N or press your brake! Once you have green light press the AUTO/H button again and drive! It is as simple as that!
01-29-2023, 05:50 PM | #20 | |
4412
Rep 7,449
As mentioned early on in this thread..the way this feature works is in the owners manual…and since iDrive has an embedded owners manual it is VERY easy to find using one of the search features iDrve. A KEYWORD SEARCH enter AUTO…should take you right to it. There might even be an embedded video (animated explanations) in iDrive.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 01-29-2023 at 06:34 PM.. |
01-29-2023, 06:35 PM | #21 |
17
Rep 148
Another benefit of Auto H enabled is when you shutdown your car, the parking brake is applied automatically. Continuous use of the parking brake lever is known to crack the plastic.
01-01-2024, 10:11 AM | #22 |
1908
Rep 5,102
Few read their owner's manual...digital or print...wow...just drive, figure shite out as you go...yep, makes total sense 😂
