BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Another N55 Procede V4 Review
      12-27-2010, 12:34 PM   #1
adrianBMW99
adrianBMW99's Avatar
90
Drives: BMW
I have had my N55 Procede for about 2-3 weeks now but have not had a chance to write a review. After thorough testing in numerous conditions, I can finally share my experience. Just as an FYI, I have 2011 335i E90 Sedan with Steptronic Auto Transmission.
I will start with the install. Most of the installation is done around the engine by plugging into different plugs as opposed to everything being done in the ECU like the N54. You start by wiring two canbus wires into the ecu and putting the Procede into the ECU box. After that, you continue letting the harness guide you around the engine into the different plugs. Everything is an absolute breeze except the Crank Position Sensor which cannot be seen by the eye and is located directly under the car's DME which is conveniently located under the engine . There is a trick to getting that plug in and numerous people have reported doing it in different ways. In my case, a friend of mine with smaller hands used two fingers to unplug the stock connector and plug the Procede one in. The install is completed by connecting power and ground. All in all, a breeze and should take no longer than 30-45 minutes as long as you know how to take the Crank sensor off which after doing a few times should be no problem.
The drivability of the Procede is absolutely excellent. The car drives and feels absolutely stock until you boost when everything goes to absolute madness. Midrange power is absolutely insane and the torque that comes in feels like somebody rammed you in the back. At any speed below 30 MPH, if I floor the vehicle with the Procede, the traction control will not let me go anywhere and If I floor it with DTC and DSC off, the car spins the rear tires and often kicks my back out. Keep in mind that I have a set of Michelin Pilot Sport Runflats which are very solid tires. Off the line, the vehicle whips your head back into the seat and will instantaneously spin the tires. I did a few top end runs with the vehicle as well; all above 80 mph and the Procede is equally impressive. Even at those speeds the vehicle manages to pull you back into your seat and when I switched back to valet (stock) mode, I quickly realized how much faster the car is with the Procede. The car feels like an absolute slug without the Procede on and does not seem to pull past 4K at all, with the unit this completely changes.
I also did a few runs with 100 Unleaded Octane race gas in Map 2 which I had previously setup as a race map. With this gas, the vehicle felt even quicker after autotuning unfortunately I had no place to do top end test runs.
Overall, I am greatly impressed with the Procede's drivability, power delivery and available features and recommend this product to anyone with an N55. I will have some videos up once I get around too it. Any other questions, feel free to ask!!
      12-27-2010, 12:56 PM   #2
Ulrich
Ulrich's Avatar
Mexico
Drives: BMW 328i 2014 8AT
Great review man, the back kick feels so good...
After several pulls at WOT did you noticed any heat soak in your IC?
      12-27-2010, 02:52 PM   #3
Freelo
Drives: 2014 328i (sold)
Adrian, many thanks for your review. Sounds very positive! Please send updates with any further impressions/observations as you gain more experience with the Procede.
I have been in the waiting line for the N55 Procede for my E90 6MT. One question I have for you is whether you feel that the power is manageable with the sport package rims/tires and no LSD. Some wheelspin is OK, but too much doesn't sound like a good thing for me. Is it manageable, or do you think you'll end up needing to change to larger wheels/tires?
BTW, I recently upgraded to the Koni yellow/sport shocks and BMW performance springs. They take out a lot of the body roll and bounciness in the stock suspension. At the same time, I also switched to non-RFT Continental DW tires, in 235 front/255 rear sizes. With 10mm spacers in front and 12mm in rear. All changes highly recommended.
      12-27-2010, 04:01 PM   #4
adrianBMW99
90
Drives: BMW
This is hard to say, I have the stock front mount and I have no way to measure IAT's. It is pretty cold in Florida this time of the year but the power feels very consistent even with the stock front mount.
You will be 100% OK with stock tires and wheels. The pilot sports I have are the ones that came with the M Sport Package on my car. No need to change anything, you will love it!
      12-27-2010, 05:05 PM   #5
IcebergM4
IcebergM4's Avatar
361
Drives: '23 M4C
Glad you're enjoying it Adrian, congrats and thanks for the review bro
      12-27-2010, 07:03 PM   #6
shockin330i
shockin330i's Avatar
798
Drives: 2016 ZCP M3
Speak for yourself. I'm ordering new wheels and tires asap. I have zero traction 1st or 2nd. I find my rear going sideways a lot lol.
ERnie
2016 BSM/f80/ZCP
      12-27-2010, 08:31 PM   #7
black e
black e's Avatar
34
Drives: DCT N55 135I
+1
      12-27-2010, 08:40 PM   #8
adrianBMW99
90
Drives: BMW
Well you have to know how to drive
      12-27-2010, 08:52 PM   #9
IcebergM4
IcebergM4's Avatar
361
Drives: '23 M4C
Originally Posted by black e View Post
+1
+2
      12-27-2010, 09:24 PM   #10
black e
black e's Avatar
34
well then, take it to the track already!!
      12-27-2010, 09:34 PM   #11
shockin330i
798
Drives: 2016 ZCP M3
I just ordered nitto 555r drag radials lol
ERnie
2016 BSM/f80/ZCP
      12-27-2010, 11:05 PM   #12
shockin330i
798
Drives: 2016 ZCP M3
And I think I just misfired.... loll
ERnie
2016 BSM/f80/ZCP
      12-28-2010, 02:57 AM   #13
diamondbar
Drives: Lexus Ls460
Hey Just curious how much did you pay after tax for your 335i sedan with m sport package and all that?
      12-28-2010, 09:04 AM   #14
adrianBMW99
90
Drives: BMW
I just might when OSW opens back up but I prefer to do it on radial as well.
Good Choice, I hear a lot of people use them.
Too much lol, $1000 above invoice add 7% FL Sales Tax
      12-28-2010, 09:31 AM   #15
shockin330i
798
Drives: 2016 ZCP M3
Yah I was up on 3rd gear and went to fourth and sputter sputter, service engin soon light came on, engine malfunton came on. Cleared the cdes and went of my merry way...
ERnie
2016 BSM/f80/ZCP
      12-28-2010, 02:00 PM   #16
black e
black e's Avatar
34
^^^how much boost?
      12-28-2010, 02:11 PM   #17
shockin330i
798
Drives: 2016 ZCP M3
^^^how much boost?
No idea, but it sure as hell is up there. The needle hits 15+ on a regular basis on map 2. Talked to shiv and he said it wasn't a misfire but rather another issue.
I still need to get my computer working so I can connect with my car. Can someone please put the link to the proper software application. I'd greatly appreciate it.
ERnie
2016 BSM/f80/ZCP
      12-28-2010, 02:13 PM   #18
jjurroz
24
Drives: 2018 F80 M3 ZCP
are you auto/dct/mt ?
      12-28-2010, 02:18 PM   #19
shockin330i
798
Drives: 2016 ZCP M3
At
ERnie
2016 BSM/f80/ZCP
      12-28-2010, 02:29 PM   #20
jjurroz
24
are you on v5?
At
      12-28-2010, 02:30 PM   #21
jjurroz
24
http://www.e90post.com/forums/showthread.php?t=470006
go get it!
      12-28-2010, 02:30 PM   #22
shockin330i
798
Drives: 2016 ZCP M3
Originally Posted by jjurroz View Post
are you on v5?
I will be once I get out of work
ERnie
2016 BSM/f80/ZCP
