HID fog lights - flickering when engine is running (why?)
02-09-2007, 06:58 PM | #1 |
Rep 18
i helped a friend of mine install a no-name HID kit he bought off ebay into the fog lights of his 2007 335 coupe. it worked fine with the engine off. it did set an error in the OBC, but the error went away after a few seconds. however, when we started the car, the fogs started to flicker like crazy - they almost looked like strobe lights. after about 30 secs of flickering, the right side fog light went off and never turned back on. we switched bulbs with the left side but still no luck.
i've searched and the consensus seems to be that mtec has the only kit that works with E90/92's. does anyone know why the cheap HID kit we installed on flickers when the car is running? i searched, but couldn't seem to find the answer. TIA this is the kit we tried to install: http://cgi.ebay.com/ebaymotors/ws/eB...m=180077178660 Last edited by drossel; 02-09-2007 at 07:42 PM.. |
02-09-2007, 09:00 PM | #2 |
216
Rep 1,793
Drives: 06' E90 330, 20' F97 X3m
u need a resistor. the stock lights run much higher than the hid ballasts. i think the hid bulbs are 35 watts and the oe bulbs are 55 watt. u need to equal out the volatge.
LIVE FAST..DRIVE FASTER!! |
02-09-2007, 09:04 PM | #3 |
LED Rules
59
Rep 789
I don't think that is the case... he states.. his friend's 335 coupe.. which is H8 35watt.... so must be the cheap crap....
LED Pimp...
13 Audi S4... |
02-09-2007, 09:08 PM | #4 |
216
Rep 1,793
possible..
02-09-2007, 09:28 PM | #5 | |
41
Rep 3,200
328xi Coupe, Montego Blue on Black with Alum, Step, Sport, Premium, CA, PDC, Cold Weather (Damn Pennsylvania winters)
Current Mods: Heavy right foot - Planned Mods: Lightweight right foot |
02-09-2007, 09:49 PM | #6 |
Rep 18
would you need a resistor with the mtec kit?
also, i don't understand why using a relay to draw power from another 12V source instead of the fog light circuit would eliminate the flickering. it's still a 12V source either way, no? unless the power for the fogs is being fed by a module (GM)? but that doesn't really make sense because they're just fog lights. |
02-16-2007, 09:13 PM | #7 |
Rep 154
Drives: 07 e92 335i coupe ED w/PROcede
i bought the same kit and had the same problem....any ideas on how to fix the problem???
02-17-2007, 01:19 AM | #8 | |
936
Rep 4,326
Drives: M340
HID Group Buy
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
02-17-2007, 09:25 AM | #10 |
Rep 6
06-16-2010, 02:42 AM | #11 |
Rep 4
Can you please contact me? while18@gmail.com
I need to ask you about install HID headlight. I can pay for it. Please e-mail me. Thanks. |
