power steering
12-12-2010, 12:06 PM | #1 |
30
Rep 299
power steering
lost my power steering......fluids fine, im running the jb3 on the n55 so dont exactly wanna take it in.......any ideas
12-12-2010, 02:24 PM | #2 |
Freight Dawg
104
Rep 2,103
Do you have active steering, servotronic, or normal?
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
12-12-2010, 09:11 PM | #8 |
Freight Dawg
104
Rep 2,103
If you hand an electronic malfunction yes. That's why I wanted to know what steering you had as servotronic and active steering lots of electronic components. With normal steering, I think the pump failed. You need to replace it.
--Marcelo
12-13-2010, 12:54 PM | #10 |
23
Rep 257
Before anything make sure you know what kind of steering you have first and be 100% sure about it. Then you can make a choise on what to do or what it could be. If its non active steering then the probable cause could be the pump but there are many factors to steering not just a pump.. You might want to have a good indy take a look at it. Or if you want the dealership.
12-13-2010, 03:49 PM | #11 |
253
Rep 7,089
Drives: '06 AW 330xi
Non-active steering cars will have a green sticker on the cap for the power steering fluid reservoir.
You can normally hear the pump going if you turn the wheel all the way to one side.....it will make a whirring sound (is that a word? lol). Also maybe a fuse? Not sure if the power steering pump is fused....I would think it is. |
12-13-2010, 07:17 PM | #12 |
30
Rep 299
o ok so i took the chip out and took it to the dealership, and yea it has a green sticker where the steering fluid is and i hear tht noise when i turn it all the way so i guess it's the normal steering so iguess it might be a pump failure
