Idrive tire monitor
12-08-2010, 12:15 PM | #1 |
43
Rep 608
Idrive tire monitor
While driving to work I got a message on Idrive about a flat tire.
I was late for a meeting so I didnt really check very well. Visually I dont see any flat tire. Can it be that the tires are running low on pressure? Or will that be a error on my Idrive if that is the case. When I check Idrive I see yellow color on all tires and have the sign on my dash panel. |
12-08-2010, 12:19 PM | #2 |
97
Rep 2,101
Check the tire pressures with a tire gauge first. With RFT's its not really possible to visually see if a tire has low pressure.
2013 BMW 328i xDrive Sport Line Mineral Grey on Everest Grey |
12-08-2010, 12:21 PM | #3 |
17
Rep 231
also if you just recently changed your summers over to your winters you would have to reset the tire pressure monitor...
everytime i swap mine it pops on after a hundred kms or so |
12-08-2010, 12:40 PM | #4 | |
43
Rep 608
I will try a reset on Idrive. If indeed I have a flat tire, whats the limit on driving with the runflats? |
12-08-2010, 01:10 PM | #5 |
1274
Rep 4,703
Since you have the yellow warning on all 4 tires at the same time it's pretty safe to say that you don't have 4 flat tires.
I think it's 100km @ 80km/h or something like that, too many factors to consider so it's probably not all that accurate. |
