Mechatronics sealing sleeve?
12-05-2010, 07:06 PM | #1 |
23
Rep 257
So my 325i is leaking transmission fluid and everything seems to be pointing to the same signs as in thread (http://www.e90post.com/forums/showthread.php?t=240526).
My question to you guys is how hard would it be to replace the mechatronics sealing sleave? Are there any techs/savy enough members/ or any one with TIS repair guide out there that has DIY for this procedure? The part alone is only like $25. The pan gasket I can do with out a problem, but how would I access the sealing sleeve? Last edited by bmw6953; 12-05-2010 at 07:33 PM.. |
12-06-2010, 07:26 AM | #2 | |
3575
Rep 10,355
http://www.e90post.com/forums/showthread.php?t=448523 |
01-07-2011, 09:09 AM | #5 |
103
Rep 2,783
Bump. What is the update?
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
02-21-2011, 08:56 PM | #6 |
231
Rep 1,473
CTSC suggested replacing this when I replace the entire pan. Any reason to do this if the transmission is not leaking? It's a $15 part and they said it should take an extra 20 minutes because it is "a bit tight" up there.
I don't even know what this part does. Thoughts? |
03-21-2011, 01:36 PM | #7 |
33
Rep 1,035
why they would use a plastic pan on an VERY expensive tranny is BEYOND me..... my damn firebird has a metal pan! Seriously considering DIY, this is basic stuff
03-21-2011, 02:08 PM | #8 | |
Rep 160
These things have plastic valve covers too...
-Tom |
03-21-2011, 02:21 PM | #9 |
33
Rep 1,035
non stressed??? they replace these at 100K and sometimes sooner because they can warp in high heat conditions, or just warp just because theyre plastic and do that.....
how much waste do you really have from a 12X18 metal pan..... |
03-22-2011, 10:15 AM | #11 |
231
Rep 1,473
Buy it from http://thectsc.com/ for less than $20 and do it yourself. They told me it shouldn't be more than an hour job.
03-22-2011, 10:24 AM | #12 |
33
Rep 1,035
I want to but i dont have a garage nor a lift, my driveway is a slight incline. On top of that I cant figure out what to do with the tranny pan, some say replace, others say just get a new gasket (or clean the old)
Additionally i dont have the proper tools like a pump etc to fill the tranny back up with fluid in a CLEAN fashion |
03-22-2011, 08:33 PM | #13 |
40
Rep 413
will dealer cover the mechatronic sleeve since theres a TSB on it if the car is out of warranty? If not I plan on replacing it myself, does this require draining the fluid?
03-22-2011, 08:45 PM | #14 | |
231
Rep 1,473
http://www.thectsc.com/images/pdf/6_...eplacement.pdf |
03-22-2011, 08:51 PM | #15 |
33
Rep 1,035
search threads ive posted in.. theres one weve gone over DIY several times. ZF diy showing pix, a written one. the main reason i chose not to is because you need to pump the old tranny fluid back in through a drain plug higher up on the tranny. Without a lift, and in the driverway this to me is more trouble than its worth
and btw thats a no. Service bulletin unfortunately does not mean recall replacement |
03-22-2011, 08:55 PM | #16 | |
231
Rep 1,473
I use this one: http://www.amazon.com/RoadPro-RP3666...0845364&sr=1-4 |
03-23-2011, 01:07 AM | #18 | |
40
Rep 413
03-23-2011, 10:01 AM | #19 |
33
Rep 1,035
I havent found a clear answer to that. Make SURE you replace the drain plug bolt, and they recommend replacing the pan gasket. If i had a garage i would have done this in a heartbeat. Just set me back 780 after tax
