2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 2011 535i Winter setup tire pressure
      12-03-2010, 08:24 AM   #1
mrh335
mrh335's Avatar
29
Drives: 2011 M3 sedan, jet black
I searched and can't find the answer other than a non-openable excel spreadsheet.
I have a 2011 535i and have the Rial Como Wheels with the Dunlop Sport 3D ROF tires. This is the 245/45 R18 setup.
I would like to know what the best tire pressure would be for this wheel tire combination. I made the mistable on my 2007 E90 to use the recommended pressure for 17" M&S with my 17" Blizzaks and in the end my rear tires wore out down the center of the tire signifcantly more than the inside or outside edges make overall traction crappy. Therefore, I do not plan to follow the recommendations for 18" tires in the BMW literature.
At present, I have them inflated to 32 psi rear and 32 psi front. I took measurements of each tire with a digital tread depth gauge at the outer, center, and inner treads for each tire and was going to monitor, but if someone else already did the homework to find the proper pressure for correct tire wear and good traction, please post it up.
Anyone know where to buy BMW center caps for these Rial Como wheels as the OEM BMW ones are too large and don't fit.
2011 E90 M3 Jet Black/Black
ZPP, ZCP, ZTP, ZCW, 6FL, PDC, shades, 6MT
      01-24-2011, 04:12 PM   #2
Jim_in_Calgary
Jim_in_Calgary's Avatar
Drives: 2011 535xi MSport - TiAg
Measure the inside diameter of the wheel bore where the roundel should go. Then do a search on ebay. There's usually truckloads of them available really inexpensively.
08 BMW K1200S / 2002 330ci Sport (sold) / 1989 635csi (sold)
07.5 GMC Sierra 2500HD Duramax LMM
09 Honda Odyssey EX-L
'75 Ford - Early Bronco
      01-25-2011, 07:37 AM   #3
Khurram
Khurram's Avatar
49
Drives: 2012 Panamera 4
tire rack also sells the bmw center caps.
5post
