Hankook EVO Ventus V12
11-29-2010, 12:45 PM | #1 |
12
Rep 204
So I just changed my summer V12s for my winters and was shocked, completely totally shocked, to see how worn out they were.
I have a 235/35/19 F and 265/30/19 R set up and I got the tires brand spanking new in May. The E90 is my wife's car, so I don't drive it all that often because I prefer zipping around in my E46. We put maybe 6K miles on them and the rear tires are almost done!!! Fronts are fine and have plenty of tread left, but I can't believe the rears... the speed at which they wore down is astounding. It begs the question as to whether we did something wrong? or has anyone else experienced this as well? I'm a bit disappointed to say the least because I actually like those tires performance-wise. |
11-29-2010, 12:46 PM | #2 |
369
Rep 8,693
Drives: 06 330i
maybe your wife has a leadfoot.
11-29-2010, 12:54 PM | #4 |
369
Rep 8,693
Drives: 06 330i
well that explains why your tires are worn....
11-29-2010, 12:59 PM | #6 |
369
Rep 8,693
Drives: 06 330i
then you need an alignment.
11-29-2010, 01:14 PM | #8 |
369
Rep 8,693
Drives: 06 330i
that probably solved your problem.
11-29-2010, 01:30 PM | #9 | |
Been there, wrecked that.
18
Rep 547
-Brian
~199K miles. I -still- don't fear my 335i. |
11-29-2010, 01:43 PM | #10 |
3441
Rep 79,211
Im disappointed in my hancraps personally, not enough dry traction.
Ive put about 8000 abusive miles on my rear tires, including many brake stands and burnouts, and races where traction was limited 1st and 2nd gear. Tires are still adequate on tread life, maybe over 50% left. Sounds to me like they were under inflated. |
11-29-2010, 03:34 PM | #11 | |
BimmerPost Supporting Vendor
2048
Rep 25,989
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
11-29-2010, 03:38 PM | #12 |
12
Rep 204
Yeah, now that you mention it I'm pretty sure that was it. Both numbers were way out of whack. At least my fronts have plenty of tread left. I keep my tires at 32 psi in front and 35 psi in the back. Thanks for the feedback. Next time I definitely won't wait so long to get the alignment fixed... I kinda just ignored the problem for too long.
11-30-2010, 08:52 AM | #13 |
251
Rep 1,636
Typically, a rear wheel drive car will go through rear tires much faster than fronts. You will most likely go through 2 sets of rears before even changing one set of fronts. That being said, a proper alignment will help the cause, but don't expect to get double the life out of the tires.
What can help is getting non-directional tires and swapping the rears midway through the summer. |
11-30-2010, 12:09 PM | #14 |
Moderator
369
Rep 4,745
It sure can...
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
