2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes will E60 M5 wheels fit F10 535i??
      11-22-2010, 02:10 PM   #1
FusionBlitzz
12
Drives: 535i
E60 M5 wheels
front is 19X8.5 +12
rear is 19X9.5 +28
will it fit F10?
I found this pic..
      11-22-2010, 03:10 PM   #2
bobblehead
bobblehead's Avatar
256
Drives: warp speed
Based on the calc., assuming non-staggered setup.
For front, the M5 wheels will have +21mm clearance on the strut and the wheel will extend out +21mm
For rear, the M5 wheels will have +10mm clearance on the strut and the wheel will extend out +16 mm.
Technically, it should fit. But I don't like the wheel to be extended by that much and thereby putting more stress on the wheel hub and there is a chance it could rub the fender. Just my opinion. You should still do an ACTUAL test fit to make sure it clears.
      11-22-2010, 04:23 PM   #3
78mao
78mao's Avatar
Taiwan
133
Drives: F10, F13, current->F80, F15 X5
2015 M3 BMW M3  [1.00]
It maybe a lil too aggressive on the front!
Im on 21 by 9 +32 and its flush flush and 21 by 10.5 +40 and its right on the fender
so going with calculations your rear should be fine, but the front is too aggressive
      11-22-2010, 07:09 PM   #4
FusionBlitzz
12
Drives: 535i
what offset will be perfect for 19inch wheels.
8.5 front and 9.5 rear? or maybe 9 in the front 10 in the rear?
19X8.5 + 20
19X9.5+ 20?
or 19X9 +30
19X10 +30
      11-22-2010, 07:12 PM   #5
78mao
78mao's Avatar
Taiwan
133
19 by 9 +30 front
19 by 10 +34 or 35 should be good!
      11-22-2010, 09:38 PM   #6
vngooi
11
Drives: F10
These are the OEM specs for the F10:
19x8.5 & 20x8.5 = ET33
18x9 & 19x9 & 20x9 = ET44
Cheers!
      11-23-2010, 10:19 PM   #7
FusionBlitzz
12
Drives: 535i
any more recommendations?
      11-26-2010, 01:48 AM   #8
FusionBlitzz
12
Drives: 535i
check out the pic
      11-26-2010, 08:08 PM   #9
FusionBlitzz
12
Drives: 535i
Front alloy wheels: 20x8.5" ET33
Wheel part number: BMW 36116792598
Rear alloy wheels: 20x9" ET44
Wheel part number: BMW 36116792599
I went to local BMW Dealer Check out the 20 " 356 style wheels on 535I Rwd..the front almost flush .like 5mm gap look down from the fender.rear is about 15mm gap.front the edge the panel...so i guss those e60 M5 wheels wont fit on F10 535I rwd
      11-27-2010, 11:27 AM   #10
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Originally Posted by FusionBlitzz View Post
check out the pic
Probably photoshopped.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      12-10-2010, 12:11 AM   #11
FusionBlitzz
12
Drives: 535i
ill try 19X8.5 +20
19X9.5+20
      12-12-2010, 01:06 PM   #12
FusionBlitzz
12
Drives: 535i
e60 m5 wheels confirmed will fit on F10 535.but the front is abit stick out ,but after lower with camber adjustment,it will be fine
      12-12-2010, 09:26 PM   #13
bmedude
Woohoo I finally got a beamer!
bmedude's Avatar
76
Drives: 2011 550i
it looks nice but I really don't understand why BMW made the offset on the F10 so flippin high!
5post
