Manual Transmission Fluid
11-21-2010, 02:34 PM | #1 |
424
Rep 1,325
OEM fluid changed at 30K. Replaced with RP. How does the fluid look? Normal? Still lifetime fluid? Followed Mr5's DIY guide which was wonderful. |
11-21-2010, 02:55 PM | #2 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
That's how mine looked. Swapped out with RP Synchromax as well.
11-22-2010, 10:58 AM | #3 |
Black on Black on Black.
38
Rep 532
I had stock fluid in, which shifted well. I swapped to synchromax because it worked very well in my old 5er, it started off very smooth, but over a thousand miles the feeling quickly degraded and it ended up notchier than when I swapped!
I ended up shelling for a bit of the lifetime fluid from a local dealer, the lifetime fluid is very good; my shifts are buttery smooth again. I'll continue to do 30k changes with factory lifetime.... Good luck with RP |
11-22-2010, 11:05 AM | #4 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Color won't tell you anything... You need to send that for analysis to see if the fluid is good or bad.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
11-22-2010, 11:16 AM | #5 |
114
Rep 2,428
I would suggest sending all the oil you change out for analysis. It's very easy, inexpensive and can tell you how your engine is running, and give warning signs of severe probles.
The company I've used is Blackstone Labs...super simple and only $25 Edit: Vasiillolov beat me to it! |
11-22-2010, 02:01 PM | #7 |
49
Rep 1,661
What brand would yall recommend using? I have to do this very soon, just hit 40k
07' MT, Quaife LSD, BMW Performance LED Steering Wheel, HPF FMIC, AA BOV, HPF Exhaust, DCI, Procede V5, AR Stage 1 oil cooler, AR OCC, AR CL DP's, Vishnu Meth Kit, UUC SSK+DSSR, UUC Shift knob, (19 inch)VMR V715's/Yokohama Advan AD08's, Hartge Pedals and Floor Mats. Awaiting Install: M3 Rear Subframe Bushings, Full M3 suspension bits, AST 4100's, DSS axles. Future plans: Vishnu Single turbo kit
11-22-2010, 02:31 PM | #9 |
49
Rep 1,661
Thanks, thats the only thing ive heard as well. Sounds like an easy decision.
11-22-2010, 05:21 PM | #10 |
Rep 44
I need to change my fluid soon.... 44k and my shifts are feeling clunky and no where near as smooth as they should. I think a clutch stop might help as well.
R.I.P. E92 335i :PROcede v4: :Vishnu DCI: BT FMIC :Catless Downpipes:
Current:AW 135i |
11-22-2010, 05:51 PM | #11 |
Rep 35
Saw this somewhere else, still not sure if our cars take D4ATF or D6ATF
http://www.redlineoil.com/news_article.aspx?id=13 |
11-22-2010, 10:00 PM | #13 | |
40
Rep 818
UPDATE: I've swapped out the Synchromax. The great shifting it provided only lasted a few months, then was about the same as the factory fluid w/60K miles on it. I put in Redline D4 ATF for use in the Phoenix extremely hot climate. According to Redline tech support, D6 ATF is closest viscosity to the factory fluid and is recommended, espec. in colder climates (D6 is about 10% thinner than D4, so not much difference -- Synchromax is a heavier viscosity than even the D4.) Last edited by AlanAZ; 02-02-2011 at 01:12 PM.. |
11-23-2010, 07:31 AM | #14 |
3576
Rep 10,355
11-24-2010, 09:12 AM | #16 |
103
Rep 2,783
Color of transmission oil might tell you something. Unlike engine oil which turns to black because of carbon.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
11-28-2010, 04:37 PM | #18 |
BMW 335I
Rep 153
I did mine today, was really black, changed with 1.5 Q of RP, my car had 60K mile, shifting is smoother and easier specailly when it is cold day
VMR701/V3/UR high cat flow/UR Full Exhaust/Sprint Booster/UR Air intake/
12-27-2010, 12:22 PM | #19 |
Rep 14
2006 325xi manual tranny fluid?
I read on the Redline website that my car (2006 325xi) takes D6 ATF for the transmission....I want to change the tranny oil out ASAP and wanted to confirm with the experts here if that jibes with what is being done in the real world...outside the stealers' network of course!!
Thanks! |
