Update: Magnetic Plug in Diff
11-20-2010, 01:16 PM | #1 |
146
Rep 942
Ok guys, I installed a magnetic drain plug on rear of my car which has just under 40k. Bought it used/CPO few months ago. So I install the mag drain plug on the diff, which only has one plug for fill; no drain plug. I've driven it around about 200 miles and pulled the plug today for inspection. It did pull quite a bit of wear particles out of the system. Nothing crazy or to get worried about. It looked like a nice coat of graphite on the magnet. I cleaned it off and re-installed the plug. The diff lube looks great... very clean looking. I'm not changing it. I drove it around for a bit to get it mixed up good and then checked it... clean as a whistle. Magnetic plugs work! I installed one on the engine oil drain plug.... in about 5k I'll see what that one looks like. Got one also for the manual trans, but I haven't figured out what kind of trans lube I'm putting back in. BMW stuff is big bucks.
11-20-2010, 02:54 PM | #2 |
1911
Rep 13,104
google Mike Miller BMW
To get his schedule he lists all the fluids and substitute fluids like Red Line
and Royal Purple. But you may already know this. |
11-22-2010, 09:03 AM | #4 |
146
Rep 942
Gold Plug. the engine plug is very sweet.
'07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, Macht Schnell Downpipes, 18" Staggered 313's w/Conti DWS's, OS Giken TCD LSD, VAC Street Diff Cover, Dinan Oil Cooler, Dinan Intercooler, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Blend V1 mount, Llumar ATR Tint.
11-22-2010, 01:52 PM | #5 |
40
Rep 818
Transmission and diff plugs are from Gold?
captainbutterbal14.00 |
11-22-2010, 04:11 PM | #6 |
60
Rep 2,334
Awesome. According to the website, these are the ones for a 335i.
Differential: http://www.magneticdrainplug.com/Aut...lugs/AP22.html Transmission: http://www.magneticdrainplug.com/Aut...lugs/AP05.html Engine: http://www.magneticdrainplug.com/Aut...lugs/AP11.html While we're on this topic, I would advise not to buy the ECS magnetic engine oil drain plug. Mine snapped while installation, and I'm not the only one. Stay away. |
11-23-2010, 07:08 AM | #7 |
146
Rep 942
ECS? What are you talking about man? My drain plug looked sweet... yes I have the AP-11. Yours snapped!!?? It's torqued to like 15 Lb/Ft IIRC. How did you do that!?
Edit: Seems ECS is a brand of vendor or something. I was going to say my AP-11 from gold plug is very sweet quality.
11-23-2010, 05:07 PM | #8 |
60
Rep 2,334
Sorry, I meant ECS tuning (http://www.ecstuning.com/). Bought the magnetic drain plug from them, and I barely applied any torque before it literally cracked. I've been changing oils all my life and never seen this happen.
Definitely will buy the ones you recommended! So do you use AP-22 for differential and AP-11 for the engine? |
11-23-2010, 06:30 PM | #9 | |
82
Rep 299
Drives: 2022 X3MC BSM/SO
My ECS drain plug hasn't cracked and I've changed my oil twice, so far. |
08-17-2011, 05:02 PM | #10 | |
160
Rep 1,307
Didn't get the engine one because I feel the oil filter already does the job, and I change oil every 8000 miles anyways. |
09-03-2011, 09:51 PM | #12 |
146
Rep 942
Not sure. Gold plug has a look up search engine. I'm assuming the diff would be at least.
09-03-2011, 09:56 PM | #13 | |
127
Rep 6,773
I have yet to install my LSD but will def be using my magnetic plug with it |
09-04-2011, 01:06 PM | #14 |
Rep 38
ECS plugs have snapped on some folks?!? YIKES! I have their and have had it in and out twice now without issues, but i will definitely be replacing it with a gold plug after your comments. There is NO WAY i want to deal with drilling out an oil drain plug! Once you pick a trans fluid, please update the Original post and give a little info why you picked that particular fluid please
09-04-2011, 01:48 PM | #15 | |
127
Rep 6,773
09-04-2011, 04:36 PM | #16 |
815
Rep 2,869
if you take your car to a dealership for work, and you have mag plugs, they won't complain about them or say they void any type of warranties do they?
Very interested in doing this for my car...
2019 X3 m40i:Carbon Black:Executive:Premium:Adaptive:Vernasca:699M:HK: Ambient:IND trim:M Mirrors:15mm spacers:Maxton lip:20% tint windows/pano:dsg paddles:TLG mudflaps
2008 328i E90 Jet Black:6MT:RWD:Premium:Sport:Xenon:MTEC V3 AEs:Front Splitters:CF spoiler:19" VMR FF v710 |
09-05-2011, 04:17 AM | #17 | |
60
Rep 2,334
I'm NOT the only one who experienced this. ECS is fully aware of this issue and yet this continue to sell the plug. Maybe mine was just defective, but be warned. Below picture is not mine.. mine snapped but luckily the threaded stem was still barely attached and I could remove it. Other owners were not so lucky. http://www.xoutpost.com/bmw-sav-foru...tuck-hole.html Another guy had his magnet fall out (can you imagine the damage if the magnet circulated into the engine?) http://www.audizine.com/forum/showth...tic-plug-broke. |
09-05-2011, 10:16 AM | #18 |
Rep 38
^^^the second pic...OMG!!! I wonder what ECS would say/do if that happened and caused catastrophic failure? And no wonder why they break...the hollowed the whole threaded section out! That leaves too thin a sidewall for the potential heat cycling and repeated torque applied along with the potential swelling of the plug and seizing due to heat. The plug needs to be made of steel realistically, but i think it's aluminum. :/ off to the store i go. Hopefully i can get one more removal out of mine!
09-09-2011, 11:37 AM | #19 |
I sweat pheromones
203
Rep 2,103
Is the magnet screwed in or glued in? If it screws in, I would back it out, apply automotive glue and screw back in. I have a Wavetrac lsd and agree with tibra's logic. Wanna get one of these provided it doesn't fall apart!
09-09-2011, 05:58 PM | #20 | |
60
Rep 2,334
On the other hand, I just got my magnetic diff and transmission plugs from Gold Plug, and they appear to be much more sturdy. Will be installing the diff one soon, then the AT one when I do the fluid change. I believe there's no thread.. it's just glued in. |
09-10-2011, 04:18 PM | #21 |
146
Rep 942
Update. Gold Plugs in my BMW, Lincoln and other family cars are doing great. NO damages. Good quality products. I'm putting one in the trans of my MKZ if I can find one to fit.
