Brake Fluid Flush Every 2 Years, is it really necessary?
11-18-2010, 03:18 PM | #1 |
143
Rep 6,333
If not, how often do you do yours?
If so, what does it really prevent?
2017 BMW M4 DCT Lease Transfer: https://f80.bimmerpost.com/forums/sh...8#post23736398
11-18-2010, 03:42 PM | #2 |
253
Rep 7,089
Drives: '06 AW 330xi
As your brake fluid ages it retains water which compresses at a different rate than the brake fluid.
Water compress more easily so you get a softer pedal feel and if there is too much water/air in the lines...your brakes will not work. So yes it is necessary. And I swap my fluid as per the BMW CBS plan, which is 2 years as you stated. EDIT: I don't use BMW fluid though...ATE blue/gold. Last edited by fdriller9; 11-18-2010 at 04:02 PM.. |
E93Dude369.00 |
11-18-2010, 03:43 PM | #3 | |
3575
Rep 10,352
And the water will also start to cause rust. |
11-18-2010, 04:54 PM | #4 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
+1 to all that was said.
In addition, water also has a much lower boiling point than brake fluid....and boiling water in the break lines = air |
11-18-2010, 05:07 PM | #5 |
Rep 157
11-18-2010, 05:13 PM | #6 |
81
Rep 4,541
Its just common practice to flush the fluid, the moisture tends to build up inside the system and with the moisture theres oxygen which relates to the spongy brake pedal feel from compressing air.
11-18-2010, 05:18 PM | #7 |
253
Rep 7,089
11-18-2010, 05:20 PM | #8 | |
173
Rep 3,415
First, water does not compress. Brake fluids do not compress. They do not compress at different rates. The non-compression of fluids is the operating principle behind hydraulic brake systems. Second, brake fluid over time absorbes a small amount of water (from the water vapor present in the atmosphere). Brake fluid needs to be replaced periodically to remove the water in the brake system. Third, water in the brake fluid lowers the boiling point of the brake fluid. When the brake fluid gets hot enough to boil, gas forms in the brake fluid (not air from outside the system), which causes the brake pedal to become soft (because gases do compress) and make the braking system less effective in applying pressure to the brake pads, which means less friction between the pads and the rotor. Water in the brake system can form rust and cause sticky caliper and master cylinder pistons. |
11-18-2010, 05:24 PM | #9 | |
81
Rep 4,541
11-18-2010, 05:39 PM | #10 |
Been there, wrecked that.
18
Rep 547
OP,
And to continue the brake fluid replacement thought - two years is the recommended time with such fluids as BMW branded fluid, ATE 200, Castrol LMA, and some DOT 5.1 spec. These fluids are designed for low moisture absorption to meet two year replacement intervals under street conditions. They work very well for their intended usage. However, if one decides to get into the specialty "racing" fluids, be aware that these types of fluids have very hydrophilic characteristics and absorb water like a sponge. These types of fluids require frequent changes to keep your brake system healthy.
-Brian
~199K miles. I -still- don't fear my 335i. |
11-20-2010, 06:08 AM | #11 |
173
Rep 3,415
And just to add... Keeping fresh fluid in the system will keep the ABS modulator functioning properly. The E9x brake system is very complex because the software provides a set of functions that rely on the ABS module working properly like brake force distribution, stability control, hill hold, etc. None of these functions operate by the driver pushing the brake pedal, but by the pump in the ABS module and control of the valve bodies inside the ABS module. Getting rust particles lodged in there would not be good.
11-24-2010, 07:29 AM | #13 |
550
Rep 6,563
this is the best short answer!
under construction! |
11-24-2010, 09:09 AM | #14 |
103
Rep 2,783
Agree with everyone about water absorption. Is it really that bad changing brake fluid every two years? For that matter changing coolant, power steering fluid, transmission fluid wouldn't be a bad idea either. Cars like clean fluid.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
11-24-2010, 10:10 AM | #15 | |
212
Rep 1,071
11-24-2010, 10:49 AM | #16 |
278
Rep 5,062
Drives: Black e92 335i
I'm about 4 months overdue for a flush.
Is this a matter of concern, or would pushing back another month be acceptable?
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
11-24-2010, 01:39 PM | #17 |
I ask the questions you're afraid to ask.
44
Rep 2,489
11-24-2010, 09:18 PM | #18 | |
253
Rep 7,089
Not to be a dick or anything but water IS compressible.....it just takes so much effort to compress it just a little bit that many consider it incompressible. |
11-25-2010, 06:35 AM | #19 | |
173
Rep 3,415
The effects of water in the brake fluid are it causes rust and reduces the effective boiling point of brake fluid. When the brake fluid boils it is less effective in transferring force, which increases stopping distances. |
11-25-2010, 09:43 AM | #20 |
30
Rep 468
While technically speaking this is true in racing the compressibility of different fluids is often considered.
Example, brembo lc600 and mogul rbf600 have very similar boiling points, but the brembo fluid results in a stiffer pedal feel especially as the fluid starts to heat up. |
11-25-2010, 09:50 AM | #21 | ||
253
Rep 7,089
04-17-2014, 07:04 PM | #22 | |
Libertarian
132
Rep 1,577
Just to clarify, and I know for a fact this to be true - liquids DO compress. Thus the term bulk compression modulus of liquids. All matter is compressible - even solids.
Bulk Modulus http://www.theleeco.com/engineering/...lk-modulus.cfm Quote:
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
