2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes F10 550i Winter Tires / Wheels Set up
      11-18-2010, 08:53 AM   #1
BigGuyM3
BBM Pin# 295E3EA9
BigGuyM3's Avatar
31
Drives: 2010 BMW M3
im getting my 550i, sport package within few days and i wanteed to know if anyone knows of any good winter set ups (rims with tires), thanx
BBM Pin# 295E3EA9
      11-18-2010, 09:17 AM   #2
bobblehead
bobblehead's Avatar
256
Drives: warp speed
Went with the stock setup 18" (style 281 18*8 et 30 f&r)
245/45/18 - Dunlop WS 3D (Dunlop WS M3 is also a very good choice too)
      11-18-2010, 12:38 PM   #3
remmib
remmib's Avatar
Norway
1566
Drives: 2013 F10 520d M-Sport
I'd go with some 18" OEM wheels.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      11-18-2010, 01:12 PM   #4
BigGuyM3
BBM Pin# 295E3EA9
BigGuyM3's Avatar
31
Drives: 2010 BMW M3
I like the Dunlop WS M3, 245/45/19.
Do you guys think 19' snow tires would be ok as well, i may try to avoid buying new set of rims to keep the cost down if i can?
BBM Pin# 295E3EA9
      11-18-2010, 02:00 PM   #5
bobblehead
bobblehead's Avatar
256
Drives: warp speed
M3 19" is okay (if you must). But you may want to stick with 245/40/19.
Your proposed 245/45/19 will throw off the speedo by 3.6% difference. Meaning, your speedo will show you are travelling 2.2 mph SLOWER than it really is.
      12-02-2010, 10:28 AM   #6
BigGuyM3
BBM Pin# 295E3EA9
BigGuyM3's Avatar
31
Drives: 2010 BMW M3
tires
Yeah you right i wanted to go with 245/40-19 just want to make sure they will go on no problem on the rear rims since stuck is 275/40-19.
and i can put none run flats on those rims right?
BBM Pin# 295E3EA9
      12-02-2010, 10:47 AM   #7
bobblehead
bobblehead's Avatar
256
Drives: warp speed
Rf or Non Rf ... your choice. The 19s have limited choices.
      12-02-2010, 05:39 PM   #8
remmib
remmib's Avatar
Norway
1566
I know Nokian Hakkapeliitta R has 245/40/19 and Yokohama iG20 has 255/40/19.
Here a F10 with the Yokohama.
      12-02-2010, 06:06 PM   #9
Bmrmeup
20
Drives: 2011 535xi, Graphite Grey
2011 535xi  [0.00]
Add Mud Flaps
Mud flaps don't look to bad on the car & they also help protect the body. I have them on my F10 535xi .
      12-30-2010, 06:38 PM   #10
markc
Drives: 2011 550xi
winter wheels and tires
I ordered 18" wheels and the Blizzak RunFlat winter tires for my new 2011 550xi from TireRack. The tires came mounted, balanced, and with the BMW tire pressure sensors in place. (There are no 19" RunFlat winter tire available I could find.) The tires are phenomenal in the snow and I highly recommend them. They perform much better than the all season tires which came on the car.
      01-10-2011, 09:56 PM   #11
bmedude
Woohoo I finally got a beamer!
bmedude's Avatar
76
Drives: 2011 550i
If possible, you want to avoid using runflat winter tires. They are way too stiff for optimal performance. I purchased Blizzak LM60's and mounted them on my stock 18's. I went slightly narrower than OEM... 225/50/18. They're a relatively smooth ride considering they're winter tires....... You definitely don't want to pass 75MPH on these things though. The car remains controllable, but the stability factor is just not quite there. Throw non RFT's on and carry a few cans of "fix a flat" in the trunk.
Purchased them from tirerack and had them shipped to my local STS. They did a wonderful job... charged 25 per tire to mount and high speed balance.
Here is a crappy photo of them
      01-19-2011, 08:28 PM   #12
5fix
61
Drives: 2020 X5 40i; 2018 m550i
I just took 18 inch winter rims off my E60 550i an replaced the 245/40/18 Dunlop Winter Sport 3Ds with 245/45/18 Dunlop WS M3s for my 550ix. (no 3Ds available.) These are my third set of Dunlop winter tires. Great in snow and ice. A little noisy after 15k. Last two sets were non RFTs, much better ride. I bought BMW mobility kit (compressor and can of sealant) for $150.
Search this Thread:
Advanced Search
5post
