Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > BMW hood roundel stud/peg broke and got stuck in hood?
      11-15-2010, 11:23 PM   #1
jahmed78
jahmed78's Avatar
45
Drives: 2007 BMW e90 335i
If anybody faced this problem while trying to remove their old hood roundel, here's what I did:
1. Push the broken/stuck stud/peg into the hood with a pencil or pen. It will fall into the abyss of the hood.
2. After pushing in the broken stud/peg you are left with one rubber grommet in the hood and a bigger hole where you pushed the stud/peg all the way in.
3. Coat the peg/stud that will go into the grommet-less hole with some silicon (avail at auto parts store for ~$5)
4. Push the new roundel in at the desired position and let the silicon set for 20-30 mins. Don's assume the roundel is in position as it will have wiggle room while the silicon sets.
I would've posted pics but I was in panic mode throughout this process...
2007 335i e90 - black on black w/wood trim and iDrive
19" BMW M-Performance wheels, ST coilovers, m3 rep front bumper and skirts, CF Hamann rep diffuser, Remus Race quad exhaust, aFe DCI, LED angel eyes & DRL kit,
      11-15-2010, 11:32 PM   #2
mithiral67
That guy
mithiral67's Avatar
117
Drives: 2015 Cayman GTS
Had one break. Just drilled out the plastic piece by going with a small bit, then a bigger bit then just popped the last little pieces out.
      12-17-2010, 04:44 PM   #3
Wake27
Wake27's Avatar
46
Drives: '06 330i ZPP ZSP
Tried pushing, didn't go anywhere so I gave up. I'll give it another shot when I can, its literally freezing and dark outside. Thought about the drill thing too. That's plan B. Pushing was the only way I got rid of the old trunk grommets.
2006 JB 330i/ZPP/ZSP/I-Drive/Heated Seats/L7/Blacklines/19" Gunmetal V710's on Vredestein Ultrac Sessantas/BMS PBX/Red MFD Scoops/Matte black grilles/Matte black Amber Gone 2.0s/BSW center midrange speaker/35% tint/Black and white roundels
      02-20-2016, 06:20 PM   #4
TestShoot
I1, I won
TestShoot's Avatar
Drives: E71 M, E60 535i
Ok, so here are photos of what I just did. I know it is an old post, BUT I wanted to give the poor next guy some pointers.
Broken roundel, broken emblem removal
The little nubs/studs were stuck flush and no pliers would get them out, nor pushing them through.
  1. Drilled a small pilot hole
  2. Took wood screw and made sure it got a bite (spun for a sec, just kept pushing)
  3. Used fingers and pliers to pop it out
  4. Grommets were safe to reuse
+-============[tSc]==============-+
http://www.TestShoot.com
Appreciate 2
4 Doors1169.00
      03-14-2017, 04:12 AM   #5
F22_Raptor
F22_Raptor's Avatar
118
Drives: 2008 328i
I gotta try this.
      03-02-2022, 04:01 PM   #6
Marcoantonacci
21
Drives: 2007 E91 328ix 6MT
Can confirm that the drill/wood screw method mentioned above is the way. Just ran into the broken tab issue and it solved the problem. Good tip.
Tags
roundel
