2010 2011 BMW 5 Series Forum F10 Pictures of F01 303 20" wheels on F11 - Opinions? |
11-12-2010, 04:21 PM | #1 |
25
Rep 90
Hi,
I got to try on a set of 20" M-sport 303s which is for the 7 series, on my F11 today. I love these wheels, but needed to check if it was possible with the offset of the wheels. I think the rear looks perfect! What do you guys think? Does the front wheel stick out too much? FYI the tyres on these wheels are for the 7 series, so too much rubber. They are 245/40/20 (front) and 275/35/20 (rear) On the 5 series they should be: 245/35/20 (front) and 275/30/20 (rear) Question: Do you think I should try out a 235/35/20 in front, to keep as much of the tyre inside the fender? Also; Is it OK to do this. A bit concerned about the fact that these wheels wasn't built for this car. Offsets are off (even though it looks nice). Is there any other cons for using different offset than the actual fitting of the wheel? Best Claus |
11-13-2010, 04:38 PM | #4 |
cidair
83
Rep 516
Wow, I think they look terrific! Really powerful wheels.
But, as You say, there are too much rubber. The diameter of the wheels are too big. One other consideration with big offset changes are that you change the wheel geometry. I donīt know if it makes any big difference with 8mm / side?
2016 435d xDrive
Previous:2019 M340i, 2014 335dx,2012 M5,2011 550ix,2008 M3,2007 330xd,2005 M5,2004 545iA,2000M5. |
11-14-2010, 07:03 AM | #5 |
1566
Rep 29,202
I think this should work and the wheels looks great, of course change the tires to F10/11 size.
The difference in offset is 8mm in the front. ET25 (F01/F07) vs. ET33 (F10/F11) Also, I think Lacster is running 20x9 ET25 on his F10.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
11-14-2010, 10:59 AM | #6 |
Administrator
40317
Rep 21,232
I think they look great. The F11 is no small car so the 20" fits it nicely.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
11-14-2010, 04:30 PM | #7 |
25
Rep 90
Yeah, I need to change tyres.
Do you think I should go for 235/35/20? F11s normal tyressize is 245/35/20. Because the offset is a bit off, maybe I should compensate with a narrower front tyre? Also: This car need to be lowered! Is that a problem with EDC? Any expert comments on this matter? /c Last edited by ClausCoupe; 11-14-2010 at 04:30 PM.. Reason: Edit |
11-15-2010, 10:49 AM | #8 | |
1566
Rep 29,202
http://f10.5post.com/forums/showthread.php?t=401721 ACSchnitzer has lowering spring for F10/11 with EDC. Take a look at EdwinF10's F10, looks great if you don't want to slam it. http://f10.5post.com/forums/showthread.php?t=451540
02-08-2011, 11:06 AM | #9 |
1566
Rep 29,202
05-28-2011, 03:53 PM | #10 | |
203
Rep 1,886
[SIGPIC]
