Wheel stuck
11-11-2010, 11:29 PM | #1 |
43
Rep 608
Wheel stuck
I was trying to attempt to swap my summers to winters but one wheel is stuck. Whats the trick on getting it unstuck?
Keep in mind, I have the car on jack and stands. |
11-11-2010, 11:33 PM | #2 | |
202
Rep 2,740
Some people like to use their feet. |
11-11-2010, 11:57 PM | #3 | |
158
Rep 6,805
Since you have jack and stand, this should be ok to do. Go to Canadian Tire and get some anti-sieze compound to put around the hub and ur rim, so it's easier for you to remove your wheels after the winter
MY07 A22 E90 N52Nxi
11-12-2010, 01:56 AM | #6 |
202
Rep 2,740
11-12-2010, 06:28 AM | #8 |
432
Rep 2,527
release the jack EVERSO SLOWLY so that the car puts some pressure on that stuck wheel (loosen the bolts).. once you see the wheel shift/pop out then raise it back up..
11-12-2010, 08:40 AM | #9 |
43
Rep 608
I think this is what I will try. I just didnt want to kick the tires as the jack mught shift and we all know what can happen even if the jack stand is there
11-12-2010, 08:46 AM | #10 |
369
Rep 8,693
Drives: 06 330i
are you kidding me? give the wheel a good kick on one side and be done with it. don't mess with the jack.
11-12-2010, 09:37 AM | #11 |
1274
Rep 4,703
Just give it a couple light kicks and it will pop right off. Make sure you put anti-seize on the wheel hub, it will prevent this from happening going forward.
11-12-2010, 04:46 PM | #14 |
chris
278
Rep 12,144
really no other way except to kick it. maybe get a friend to help?
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
11-12-2010, 10:49 PM | #15 |
Rep 187
Since you are using proper kick stands, keep one lug on slightly (to prevent it from falling) and then hit the tire with a rubber mallet or kick it.
11-21-2010, 12:38 PM | #18 |
38
Rep 430
Probably a lot safer. There is no way that I would want to kick a wheel when the car is on stands. If I were going to kick a wheel, I would just lift that single corner slightly off the floor. ER's are too crowded already without people kicking cars on jack stands.
2009 328i |
11-24-2010, 02:40 PM | #19 |
Dreamer
34
Rep 837
