Help! Xenon Error
11-11-2010, 10:36 PM | #1 |
Rep 169
Help! Xenon Error
Hey Guys,
I've did a Halogen to Xenons conversion a while ago, and I always had errors during the fall/winter (lights not turning on, or the stupid error tone going off every couple minutes). This year I decided to do something about it, and purchased an HID kit that has the correct 55w voltage. Everything installed fine, until... I drive for a more than 5 minutes... After 5 minutes pass I get the RED SERVICE light... yea the one that's a picture of my car on a lift... The error code was CCID 231. I did some quick research and I am not the only member that had this problem after popping in a HID kit. Does anybody have any solutions? I remember a while back people mentioned error cancelers, but I haven't seen those in the forums for a long time. HELP! It gets dark so early, and I'd like to drive w/my lights on w/o the errors. Thanks! |
11-18-2010, 04:12 PM | #2 |
165
Rep 7,433
bump, this just started on my car today
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
01-04-2011, 01:54 PM | #3 |
Rep 169
Note: My battery was dying, and when I swapped out the battery, the error code stopped appearing (it appeared once after a changed the battery but since then it hasn't appeared again.)
I just swapped to an ******* HID kit, seems to have fixed the problem... Unfortunately this kit does not use the D1S bulbs, so the beam pattern seems a little bit off. I'm currently trying to find a solution where the I can use D1S bulbs with my ******* HID kit. Has anybody tried this? The HID kit I have only has 2 wires for the bulb... D1S bulbs have 3 pins, requiring 3 wires... Does anybody have information related to which wire is +/- or ground? I cut the OEM D1S cable and noticed the 3 wires are the following colors: Grey, Pink, and Yellow. In retrospect... I sort of wish I kept my xenon swap w/OEM kit... too late now... |
